Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite HE4t front load washer completly dead panel after error codes not ccu
Appearently these HE4t's have a history now of bad electronics controlling the machines funtions. Bad enough to prompt a possible class action suite against sears. Any real experence operational sequence techs want to respond to this. The electronic boards are Italian made for whirlpool.
Bob
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
Whash machine
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Thanks
Feb 04, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Kenmore elite he4t f33
The F33 code can indicate a bad pump or a problem with the wiring either at the pump or the CCU (central control unit), or the wiring harness itself. Before you replaced the pump, did you test the resistance in the wiring harness?
Unplug the washer and use an Ohmeter (VOM) to test. See http://media.fotki.com/1_p,wtftddqbdtwbdkrxgtqsskgwtqkq,vi/tgdkbwkswxfddbwsbdbxtbgtgwftb/1/1303472/5961857/image49983img-or.gif for the schematics of the wiring for the pump on the CCU. To access the CCU, you need to remove a few screws on the back of the top panel. You remove the lower service panel on the front of the washer to access the pump. The wiring should read 12.3 ohms at the CCU. If you get a reading of infinity (open), check the pump. If the leads to the pump motor give a resistance of 12.3 ohms, then the wiring harness should probably be replaced. If the circuit to the pump is fine and the error persists, then the CCU is faulty and needs to be replaced.
I hope this helps. If you add a comment with the specific model of your washer, I may be able to give additional suggestions.
Dec 23, 2012 | Kenmore Washing Machines
Washer won't unlock flashes f14.....Kenmore Elite HE4t
F14 for Kenmore (Whirlpool) machines means EEPROM Error.
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU, if there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error. Check CCU. So its likely you'll need a new CCU board.
Check your owners manual, some models have up to a 5 year parts warranty on that CCU.
Jul 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
We have a Kenmore Elite hE4t front loading washer and now it keeps flashing FH code. We have followed all the troubleshooting suggestions - checked water faucets, checked inlet hoses for clogs, no kinks...
check the mesh on your water inlet valve. could be a problem with the valve or the pressure switch.
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
•Verify there is not a siphon problem
•Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
•Check all hoses for possible leaks
•Verify pressure switch operation
•Verify flow meter operation
•Verify CCU operation
Feb 13, 2011 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
HE4t Washer
"F06" is a Motor Speed error. The following link explains how to troubleshoot and some common causes:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
The first step to troublehsooting should be to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that it takes to correct momentary glitches with the unit. If the error code reappears following a computer reset, follow the advice given in the link I provided.
If you have questions, or require additional assistanc, please let me know. I hope this helps you.
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Getting fault code f14?
F14 = EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU.
If there is an error reading this data, it will cause this error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Oct 15, 2008 | Kenmore Elite 45986 Front Load Washer
F Code for the Kenmore Elite he4t Front Load Washer (3 years old)
Hi! ricksmith
What is the first three digits of the model number.
The he4t I have reference to does not have a "F" code error. Most of the codes are two digit, PF, F1 to F9 etc.
You could try: Pressing Pause/Cancel two times to clear code. As well as unplug for 20 seconds. Do you have power fluctuations in your area.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite error code
possible electronics failure. my HE4t has completly gone dead at the control panel after displaying error codes. A class action law suite is in the works on the HE3t HE4t machines.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
213 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
