SOURCE: washing machine spins but doesnt drain water until I turn it back to spin only
timer contacts are burnt replace the timer
SOURCE: washing machine won't drain water nor spin
hi, sounds like you have a blocked pump, it is located on bottom right of machine, it is a very simple fix, just remove pump and see what is inside, remove it and you should be all good. :)
SOURCE: Avanti W852 Parts??
It's going to be hard finding parts for this machine because I have one as well. You can search the internet or call the company. The last time I had problems with my machine the company told me they stop making parts for this particular brand. Don't give up looking for parts, maybe someone else sells the parts for this washer. Good Luck!
SOURCE: washer does not spin
that wont cause it not to spin but it just jerks the tub around a bit stronger.you most likely have a bad clutch.you can take front panel off and see if your clutch is grabbing when you put it in spin.it is under the motor.
SOURCE: Washing machine problem
"dE"
- Lid open error
Lid is open during wash cycle.
Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board
"OE"
- Water overflow error
Water supply does not stop after sensing an overflow condition.
Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
