Question about Jenn-Air JCB2388G Side by Side Refrigerator
Warm side by side freezer and fridge
A few days ago, I noticed alot of frost on everything in freezer. Throughout the day today, the temperature of the frig and freezer has increased to almost room temp. the fan is running. removed back panel and find fan working and hole at bottom not plugged, and of course the frost has melted. what should I replace??
  • 943 Answers
Hi thanks for your question. i would clean the coils at the back of the fridge. it could be just dusty try that
Posted on Oct 17, 2008
SOURCE:
I bought a hisense fridge a month ago, it was Ok when we connected just for couple of days, I turned the temperature up a bit so the freezer can be colder, but now
Hisense is a company that makes cheap budget end televisions. Sounds like the defrost timer may have failed. The cold is created at the rear of the freezer and cold air is vented to the fridge. Have it looked at under warranty.
Feb 02, 2017 | Frost Refrigerators
KFIS29PBMS00 gets warm after a day of work
sounds like you need a repairman's services
Jun 24, 2015 | KitchenAid Refrigerators
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
My fridge goes through warm cycles
hi , Glad to help you...
your freezer cabinet need to get all out and open the back wall.
  1. you have 2 element that can be check one is the heating element , two is the thermostat.
  2. you need a volt meter to check them.
  3. if the frost is all over the coils then one of the element i told you before, is bad
  4. if the frost is in one area not all over then you got gas leak.
  5. good luck 911service today . com
  6. I hope you find this Very Helpful and best regards!
Jan 05, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Defrosts/refreezes
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Aug 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
A funny smell and i think it might be the temperature
Adjust the knob to 3 or 4 which would be the midway temperature.
0 would probably be off or close to it. The 7 would be coldest and freeze water.
If this is manual defrost you need to turn it off and defrost it. The frost will keep it from getting cold enough. The buildup is normal from humid warm air when opening the door. You might get a standalone fridge / freezer thermometer (about $5) to tell you what temperature is. The smell may be food spoiling from warm temperature.
Mar 20, 2009 | Danby DDW1805W Designer Series...
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Fridge wont get cold and freezer gets cold then gets warm
Sounds like to me you have a defrost issue. If your fridge is only 2 months old don't sweat it and call out a Whirlpool warrenty certified tech. to fix the problem. And sorry to say age does not matter with fridges any more. The good ole days of fridges lasting 20 years is over now it's 12 years if your lucky.
Feb 24, 2008 | Jenn-Air JCB2280HES Side by Side...
Motherboard
Yes it certainly could be. You dont hear the fan in the freezer anymore?? Is the back panel in the freezer covered with frost???
Nov 23, 2007 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Jenn-Air JCB2388G Side by Side Refrigerator Logo
156 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
