Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Hitachi 57F500A has ghost colors
We have found the grid to straighten the bends in the color but do not know how to use the remote to fix it. Can you help?
    Scholar:
  • 71 Answers
Here is a clip of page 57 of the user guide for your TV. It specifies the remote functions to complete your convergence. Or, you can download the entire guide at: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on May 04, 2009
SOURCE: sony KP-53N77
well I personally like rear projection sets with tubes in them better than the new HD crap but Sony or Hitachi would be my choice if I had to buy one of the new format sets, good luck with it & Happy New Year, BMW Rider
Posted on Dec 31, 2007
  • 579 Answers
SOURCE: CONVERGENCE GRID IS OFF ON MY RCA P61929
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it. If that doesn't work the nodules need replacing.
Posted on Jan 03, 2008
MikeNJ1964
  • 398 Answers
SOURCE: Hitachi 53uwx10b Convergence
You must have the original remote to do complete convergence adjustments. Remote method: Press MAGIC FOCUS button on front panel to start the magic focus. When magic focus is running, press MAGIC FOCUS again. STOP should appear onscreen. Immediately press RECALL or STATUS on the remote (must be pressed before STOP vanishes). The set is now in DCAM (Digital Convergence Adjustment Mode). Manual method: Remove the front grill and access panel or reach around from the back and press the little pushbutton located in the front left corner of the PC board, next to the Digital Convergence Module.
Once in DCAM, the remote buttons STATUS selects green, 0 selects red and ANT selects blue. 2,4,5 and 6 move the cursor and the thumbstick makes the corrections.Make all necessary corrections and then press PIP MODE. The words ROM WRITE? appear onscreen. Press PIP MODE again to store settings. When green dots appear, press MUTE to return to convergence pattern. Press PIP MODE (ROM WRITE? appears again) and then press PIP CH. This will Initialize the internal sensor data positions. When INIT finishes, press POWER on the TV and convergence is complete.
Posted on Mar 27, 2008
  • 77 Answers
SOURCE: tv duplicate image
your guns are off and need to be adjusted. your 3 guns (red, green and blue) are off and that would explain the funny colors and shadows. Have a tv tech come out and have a look, they can fix it for a reasonable price.
Posted on Oct 20, 2008
SD Tech
  • 14553 Answers
SOURCE: Hitachi Projection TV 57F500A red looks double.
You need to replace both of the convergence IC's and any bad resistors around them that protect them from damaging the power supply.
This repair can usually be done in the home and takes about an hour; I have done hundreds of them and now is a slow time of year for TV shops; look around if you are not able to do this repair; you can buy the chips on Ebay for less than 15 dollars for a pair plus shipping.
This is a very common problem in projection sets.
If this has helped you give me a vote here as I do this for free. If you have questions or need help:
etower.766@netzero.net
Posted on Aug 23, 2009
I have a projection Hitachi 57F500A the color is very yellow, I lived with it until the screen starting having the same image as the one I see in the covergence repair kit ad. I think I have two problems....
Its very unlikely that you have a bad tube in this model..that would be very rare...it may just be the convergence or possibly the fluid in the lenses has clouded up. Both are common issues. Read this and see if it helps http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 21, 2011 | Hitachi 57F500 57" Rear Projection...
Hitachi 53uwx10b Convergence Grid Tilted A Little...
If the tilt is not that bad, I would leave it be. The reason is yes you can straighten the tilt out, but it requires a mechanical alignment to all 3 CRT's then you will have to align the convergence on all 3 as well. Please take a few moments to rate my answer. Thank you.
Nov 18, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 57G500 the green has dipped down in the color grid
U can't adjust this,Ur convergence is dead.U know how to solder?Buy ur tv name and brand the covergence kit,replace what the parts in that kit.
Sep 24, 2009 | Hitachi 57G500 57" TV
On my Hitachi 57F500A the red looks doubled. I
This is usually cause by bad convergence IC's with part# STK392-110. There are two that need to be replaced.
Aug 20, 2009 | Hitachi 57F500 57" Rear Projection...
I have 46ux13k hitachi tv and i need to know if there is atrick to adjusting the convergence.
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACHI REMOTE. NONE ELSE WILL DO
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
ONE COLOR WILL NOT MOVE. YOU WILL NEED TO MOVE OTHER COLORS TO ALIGN TO IT.
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Mar 21, 2009 | Hitachi 43FDX01B TV
Hitachi projection tv
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 14, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 50ux57b
The green and blue ghosting is a convergence problem that is either bad connections at the convergence ICs or defective ICs. If you can solder, try resoldering the ICs. If that fails to resolve the problem, replace them. These ICs are large black ICs attached to a heatsink. They should be marked STKxxx.
Keep us posted.
Dan
May 13, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 43FDXO1B Convergence?
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
17) Turn power OFF.
Jan 13, 2008 | Hitachi 43FDX01B TV
Color ghosting
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 11, 2007 | Hitachi 50GX30B 50". Rear Projection...
Hitachi 53SDX20B Bule ghosts
KIT10 $29.50
Oct 31, 2007 | Hitachi 53SDX20B 53" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
110 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
