Toutside a/c unit fan quit spinning
The fan quit spinning but was still buzzing so i turned the unit off and then back on and turned the fan with a stick and it started spinning and keep spinning but there is no cold air coming out and every once in a while it brings the electricity levels down enough to dim the lights what is my solution
  • 89 Answers
Sounds like starter on a/c is going out you need to replace it as it starts the fan and compressor as well good luck (thats assuming toutside means outside)
Posted on Aug 23, 2008
Turn on AC but outside unit fan doesn't move
Either a very bad Capacitor, or the fan belt came loose and the motor is just spinning
May 26, 2014 | Empire DV-215 Direct Vent Natural Gas...
I have a Goodman CPLE30-1A outside unit and the fan stop spinning. The fan stop spinning so I turn off the main power to the unit and I can spin the fan with the power turn off so I'm not sure if its...
Hello
There are a few things here that could be wrong.
1 Fan motor start capacitor is bad.Silver battery looking device on side of fan.Remove and replace with a new one.
2 Contactor for fan motor is pitted or burnt .If this is the case you will need a new contactor.
3 Fan motor is bad.Check top two before assuming this.
Check all fuses and circut breakers also.
Aug 29, 2011 | Goodman CKL42AR42 Air Conditioner
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
After oven turned on for normal baking it starts to hum rather than typical noise from exhaust fan.
If you're not hearing the fan turn at its normal speed, it is possible that your fan motor has become stalled. AC motors will often hum or buzz when they can no longer turn but still have power applied to them. This could be due to bad bearings, or a blockage of some sort. It's probably not easy to get to, but if you can hand check the fan it should spin quite freely. Be sure to unplug the unit before messing with the insides, or shut of its circuit breaker if it's a built-in unit.
Dec 24, 2010 | Dacor ECS130 Epicure Electric Single Oven
Our window AC/heat unit fan only buzzes when turned on- no matter whether you turn on fan only or heat or cool mode.
so the fan does not spin and blow air? it could be a stick broken fan try free spinning it make sure its turned of. if fan spins freely its probably your start capacitor which is not to expensive.
Nov 10, 2010 | LG Heat cool Window Air Conditioner
Have a Ruud Achiever Model number UAKA-037JAZ that won't run since yesterday. When the air kicks on it simply makes a buzzing noise and the fan doesn't spin. Can anyone help?
try spinning by hand when the unit make the buzzing sound. to see if the capacitor is bad. If the fan runs replace the cap. If not motor probably is bad. See if it spins freely. this is a good starting place. need to check if the buzzing is the contactor and there is no power to the condensor. The contactor will buzz even though the main breaker is off or tripped
Aug 10, 2009 | Ruud UAKA037 Air Conditioner
Air Conditioner Compressor Fan Quit
Check the start capacitor. You may be able to see visual deformaty, otherwise, use a meter. The buzzing is most likely the contactors closing which uses a seperate 24v supply..
Jun 26, 2009 | Kenmore Heating & Cooling
Carrier AC 38CKC019 may have overheated. The fan unit buzzes but does not turn.
Hey there, ok, now if the fan is spinning and the compressor is buzzing, the compressor is locked up and needs to be replaced. If neither is running and the buzzing is coming from the control panel on the unit, it could be the contactor. Also there is a chance that the fan motor burned up, causing the compressor to fail so the fan would be off but the compressor is buzzing and locked up. If nothing is running also check the circuit breaker it could just be he conactor you are hearing. At that point you need to figure out why the breaker tripped. Let me know what you find out
seth
Jun 25, 2009 | Carrier 38CKC018 Air Conditioner
Recentley my tv just turned off. I heard a buzzing sound which happened the 1st time my bulb went out. So I ordered a new one. When the new one was put in it worked for 5 minutes then turned off and...
This could be a couple of things. Look at the cooling fan and be sure that it can spin freely. If it is stuck, the buzzing could be the motor trying to spin the fan. Other than that, the ballast could be failing as well. This is the part that "fires" the lamp. Examine the fan first and let mw know what happens.
Dan
Jul 22, 2008 | Televison & Video
Heating & Cooling Logo
133 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
