Question about VIA P4MA Motherboard
On-Board USB Problem
My usb port won't detect any device plug into it. My O.S. is Windows XP
and a hardware with a specification of:
RAM: 128 MB
Chipset: Via 82C691 re 68
Super IO: Via 686 rev 27 at PCI 7
Manufacturer: Via Technologies, Inc.
M/B Number: VT82c692BX
Bios Type: Award
OEM: Bios 2M(2K000218A) Super 133 Support 133MHz System Bus - 6.00PG
  • re: charcois
    I already tried that one still nothing happens...
  • vikram_jeets Sep 27, 2008
    facing the same pro.
  • 70 Answers
Try a BIOS flash (but be careful, it's easy to bugger this up).
I'd also suggest trying a PCI USB card to clarify whether it's a hardware or software issue.
Posted on Aug 23, 2008
    Master:
  • 763 Answers
Try to download and install a USB driver or came with your motherboards cd it has a usb driver too. hope that helps!
CHARCOIS
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
Windows 7 64bit with support for USB 2: when I plug my pendrive in a USB port, there's an advice saying that if I plug it into a USB 2 port, it will perform faster. But how do I know which port is USB 1...
I hate this message.
You can use a program like PC Wizard from CPUID that will tell you what all of you pc specs are.
From your specs you may not have usb 2 ports.
Device manager should also say what usb ports you have.
The best ports to use are the ports on the rear of the computer, front usb ports sometimes dont have as much power to drive external hard drives or high drain devices
Jul 10, 2010 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
System is not detecting
To determine if your system is detecting the USB drive or not
Windows XP Right click "My Computer" >> Properties >> Hardware Tab >> Device Manager
Windows Vista/7 Right click "Computer" >> Properties >> Device Manager
If your USB drive is not detected at all either the drive is bad or the usb port is bad, I would try another USB port to rule out the issue being a port
If you see a ? or ! then your operating system had trouble installing a driver for it uninstalling and reinstalling the driver should resolve the issue
Please comment if you need further assistance or clarification
Thanks
If
Nov 21, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have just brought dell latitude e5500 laptop. i wanted to connected the hp officejet 5610 scanner to my laptop but am not able to do. please help
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab19
Jul 11, 2009 | HP Officejet 5610 All-In-One InkJet...
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Hi tried that... sound card is connected and vm-ware tools is also installed... its surely a problem with the windows 2003 server. because the error sound is played through the macbook speakers but not any...
see heres the thing when using VM-Ware, VM-Ware doesnt use drivers for your physical hardware, because it emulates the hardware that is seen in the hardware information of your system preferences.
So installing even drivers for the "emulated" hardware will not work, as VM-Ware uses its own drivers for the hardware, which are included with the VM-Ware Tools, if that doesnt seem to work, you may want to contact VM-Ware support, as they may have a better solutiuon.
Aug 29, 2008 | Intel Motherboard
Usb ports not working
All the USB ports were working before he installed SP3 and rebooted. After that only the mouse/keyboard ports worked. Same thing happened to me. No other changes were made, so something added/change by SP3 is the culprit.
Questions is...what did SP3 do to break USB and how to fix it?
Jun 14, 2008 | ASUS A8N-VM Motherboard
USB 1.0 to 2.0
The answer is probably to fit a USB 2.0 card internally
This link says it all.
http://ask-leo.com/how_do_i_upgrade_to_usb_20.html
Apr 13, 2008 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
The flash drive purchased doesnot work when pjugged into the usb port on my desk top but it work on my lap top? How do I get it to work on my desk top
Hello claponte
FIRST, THE HARDWARE SIDE:
If you just purchased your flash drive, then it is using the USB 2.0 (high speed) standard. Prior to that were USB version 1.1 and, before that, USB 1.0 standards.
USB 2.0 devices will still work when plugged into USB 1.1 ports - just at a reduced speed)
However, computers w/ USB 1.0 ports cannot properly detect USB 2.0 devices. On those computers, you'd need to install a USB 2.0 expansion card in order to add USB 2.0 functionality to the computer.
SECOND, THE SOFTWARE (DRIVERS) SIDE:
On the software side, USB devices are "plug-and-play" on Windows XP & Vista systems. This means they do not require special drivers or installation for them to work properly. The drivers needed for them to operate are already built into the operating system.
However on operating systems prior to Windows XP (Windows ME, Windows 98SE, Windows 98...) drivers are needed for USB devices to be detected properly.
These are two possible reasons why your flash drives don't work on your desktop computer.
(01) The computer is an older one using USB 1.0 technology
(02) The operating system is pre-Windows XP
Another possibility is (if your computer USB ports are at least 1.1 standard and your operating system is at least Windows XP) there is an issue w/ the USB ports on your desktop computer. This could be a hardware or a software issue still.
Please, let us know if that's the case and we'll help you to trouble-shoot the issue.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Computers & Internet
Usb external drive not getting detected
i dont think usb version2.0 was popular when pentium 3 was around, get a BIOS uprade for your board if you can,
failing that a more up to date board and chip, with windows xp will sort this problem out and it will run so much faster as well
Nov 05, 2007 | Intel Motherboard
VIA P4MA Motherboard Logo
180 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
