My washer will not drain or spin the water out
  • ddark1234 Aug 23, 2008
    machine full of water, will not drain, was making a noise..like a coin in it when on drain or spin. How do i empty it ? Hoover Autowasher 1200 soft~wave
  • 89 Answers
Sounds like pump problems the washer wont go into spin cycle until pump drains water so until pump gets replaced the way to get water out is a bucket sorry wish could help more
Posted on Aug 23, 2008
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
Washer fill or drain but does not spin
It's not supposed to spin during water fill and draining, if I understand your post.
Charlie
Aug 23, 2009 | Kenmore 44102 Front Load Washer
Spin cycle
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 04, 2009 | Kenmore 24422 Top Load Washer
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Ge washer not draining or spinning
HI yes you can remove the pump and clean. the pump is the problem
Oct 12, 2008 | GE WBSR3140DW Top Load Washer
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
140 people viewed this question
Top Washing Machines Experts
