Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Paper enters printer at an angle
One side of paper enters printer faster than the other side.
    Sergeant:
  • 241 Answers
Clean the rubber rollers with a diluted alcohol and wipe down. They get dirty all the time and you could also have a piece of paper stuck inside too.
Posted on Aug 28, 2008
Printer using to many pages at once
When printing in moist climate or conditions, be sure to fan your paper before loading printer. Also set your paper guide so that the paper does not pull in on an angle.
Mar 25, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Printer pulls paper in from one corner
this problem occurs only when one side of the paper spooler is jammed and stuck. the spooler pulls the paper causing the paper to rotate inside the printer and getting stuck.
take professional help in clearing the jam and freeing up the spooler.
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma 5000 - paper feeds such that one side goes in faster
Your rollers are not up at that side, try manually raise them up to see if that helped.
Nov 24, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper.
"paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper."
I am having the same trouble, what was the solution?
Oct 15, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
May 11, 2009 | Canon LBP 1120 Laser Printer
My printer has started feeding the paper through on an angle which is causing ti to jam in the right hand side. The paper therefore does not feed through and printing doesn't happen. My guess is that one...
Clean the pickup rollers with a damp cloth, and dry the rollers with a clean part of the cloth. If it is still feeding paper in scew, then there could be something stuck inside the printer.
May 29, 2008 | Office Equipment & Supplies
Canon i475D Printer
Try cleaning the rollers where the paper feeds in, a cotton bud with metho works on my printers
Apr 15, 2008 | Canon i475 InkJet Printer
Loading printer paper
Where I was guiding the paper, after feeding the paper through the back of the machine (the slot is located on the outside of the back of the machine), the paper naturally wanted to enter underneath the black plastic plate where it would end up underneath the entire printing mechanism. As the instructions indicate, the paper does not actually feed "under the black plastic plate", it should feed through it. There are two rectangular silver tabs, one on each side of the proper paper entry slot. I cut the paper at a very slight angle and finally found the magic entry point. Also if you make an arrow with the paper by folding the sides, it will help guide it in that tiny silver slot. Because the machine is so tiny, that entry slot is almost invisible, except for those two silver tabs. After you manage to insert the end of the angled cut through the "invisible slot" be sure the entire edge of the paper actually enters the slot so that when you push the "Feed" button, the paper is grabbed and fished through evenly. Hope this helps somebody!
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; document.getElementById("ga_300x250").style.width = "370px"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //-->
Mar 19, 2007 | Canon P1-DHV Calculator
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
