Question about GE 21028GE3 Cordless Phone
I have a GE wall phone. I want to know how to program the memory dial
My phone is working. I would like to know how to program the memory dial. I do not have a manual.
Model # is 29255GC1-C. I don't know how old this phone is, it came with the house when I bought it.
Thanks for any help.
Hughlan (Skeeter) Holeman
email is: skeeter5 at dishmail dot net
  • skeeter5 Sep 11, 2008
    Thanks for the answer. It is greatly appreciated.
    I wish you a nice day as well.
    Skeeter5
I just found the info on the internet. Here follows :
1) Pickup the handset
2) Press the STORE button once
3) Dial the number to be stored (max 16 digits)
4) Press the STORE button once
5) Press the A, B, or C button once
6) Hangup the phoneset
Then just press the A, B, or C button once when need to dial the stored number.
Have a nice day !
Posted on Sep 09, 2008
SOURCE:
Need to know how to put numbers in memory dial for ge model 29318ge1-a corded phone
hit store, then dial number you are calling, then hit store button again and choose the number you want it stored in.
Jan 04, 2010 | GE 29318GE1 Corded Phone
Programming memory
Click below to download manual;
Download User Manuals
hope this may help;
regards,
VOTIT
Jul 30, 2008 | GE 29897GE1 Corded Phone
GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
May 28, 2009 | Uniden Cordless Phone
How to enter phone numbers into the memory/speed dial?
The manual from the GE web site is here:
http://www.home-electronics.net/ge/pc/IB/29267GE3_IB.pdf
It's a pretty straightforward process, Pick up the handset press STORE a location (0-9) STORE dial the number STORE
With only 10 storable numbers it's pretty thin, but you also have the last 50 CID numbers to dial. If you live in an area with more than one local area code (overlays) and mixed 10 digit dialing, it looks like you may have some programming to do to make it dial CID numbers properly.
Carl
Apr 21, 2009 | GE 29267 Corded Phone
Need help programming autodial feature on my ge-27923-ge cordless phone
how do you change GE Model 27923 2.4 GHz cordless phone from pulse dial to touch phone dial? I lost my instruction manual Thanks
Apr 15, 2009 | Lands Phones
Instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
STORING A NUMBER IN MEMORY
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
Aug 11, 2008 | GE 29322GE1 Corded Phone
Speed dial instructions
make sure phone is off not in talk mode- then press the memory buton-press desired number 1-9-press memory button again,the display shows enter name -press memory button to save the name.then the display shows enter number-enter the number then press memory again and you will hear a tone that confirms
Oct 05, 2007 | Uniden Cordless Phone
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
CHANGING A STORED NUMBER
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Apr 27, 2007 | GE 29318GE1 Corded Phone
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
GE 21028GE3 Cordless Phone Logo
292 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
