Question about Char-Broil CharBroil 4637318 Grill
I have a char-broil 3 burner grill that is about 6 years old. It has 3 circular burners. The amount of gas now getting to the burners is equivalent to low even when the dials are on high. Do I have a burner problem or a regulator problem?
  • 89 Answers
Most likely burner problem try removing burners (they generally just lift out or held by 1 or 2 screws) clean the sides of the burners with wire brush most likely then orifices on burners are clogged hope that works for you
Posted on Aug 23, 2008
How to replace regulator/hose/valve assembly on char-broil gas grill?
Follow the hose back to where it connects to the gas rail , and go from there , to see what has to come off if anything .
Apr 21, 2013 | Grilling
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
I'm trying to replace the paddle burners on this grill, but I don't know how to get the old ones off. Char-Broil said I have to disassemble the entire firebox to replace them. Is this correct, or is...
Hello, The model number that you gave is relatively simple to change the burners.
  1. Remove the 3 cooking grids
  2. Remove the 3 vaporizer tents
  3. Between each burner is a "pal nut" that just pushes on and will likely be destroyed when you remove it. They run a couple bucks each at Sears, part # 7000132
  4. This will release the carry over tube holding the burners down and the burners can be lifted out.
  5. Ensure that you clean out the carry over tube when you reassemble. This carries the flame from the first burner across to each of the rest of the burners when lighting them.
  6. Reassemble in the reverse order ensuring that you put the burner tubes over the burner valve tubes when reassembling.
You can find an exploded view with all the parts numbers at: http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001103_463453305_a.pdf
If this was helpful, please vote yes. Thank You!!
Oct 04, 2010 | Char-Broil Advantage 463453306
I'm trying to replace the burner on a Char Broil Master grill 7000
Should be able to get the burner assembly at any Lowes or Home depot store and not hard to change out. Old one lifts out and new sits right in. Hope this helps.
Mar 19, 2010 | Char-Broil 7000 Quick Set Gas Grill
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
Char Broil grill w/full tank and cleaned air jets, no heat
try opening the tank really slowly. if you open it too quickly the overfill protection devise in the tank will restrict the gas flow to the burners. hope this helps.
Sep 17, 2009 | Uniflame FG2204C Grill
New Char Broil gas grill heating issue
Did the kit come with NG orifices and did you use them.
Jun 23, 2009 | Grilling
Charbroil master flame gas grill the flame is either very high or very low
How old is the grill? The size of the holes in the burner is critical. As burners age, the holes rot out, and get bigger. The velocity of the gas exiting the holes has a large effect on flame size. New burner is the most typical solution.
Mar 08, 2009 | Char-Broil CharBroil Master Flame Gas...
Char-Broil CharBroil 4637318 Grill Logo
127 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
