Paper enters printer at an angle
Paper alignment is off as it enters printer. one side goes in faster than other side of paper. then jams.
  • 157 Answers
Hello sir
Posted on Aug 23, 2008
  • John Smith
    John Smith Aug 23, 2008
    Turn printer off. Take cartridges out. Turn on then off. Put cartridges in. Align cartridges. Re-install printer drivers and software
    Cheers
    Hope that helps
    JigSaw
My canon printer is getting jammed, when it tries to run thru it goes on an angle to the left side and gets jammed, How do I fix this?
That means that there is something jamming the paper on the right side. Check to see isf there is some paper residue from a previous jam near the rollers.
Also do the following:
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 27, 2011 | Canon PIXMA® mini260 InkJet Photo Printer
Printer pulls paper in from one corner
this problem occurs only when one side of the paper spooler is jammed and stuck. the spooler pulls the paper causing the paper to rotate inside the printer and getting stuck.
take professional help in clearing the jam and freeing up the spooler.
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
Canon Pixma 5000 - paper feeds such that one side goes in faster
Your rollers are not up at that side, try manually raise them up to see if that helped.
Nov 24, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper.
"paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper."
I am having the same trouble, what was the solution?
Oct 15, 2009 | Canon PIXMA MX330 Multifunction InkJet...
HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Mar 13, 2009 | HP Officejet 6200 All-In-One InkJet...
Alignment error after replacing black ink. Lexmark X5495
I found a pencil inside my printer and took it out. It was not easy but now it does not jams the paper. Disconnect the power cord and softly shake the printer from side to side making sure you are holding on to the top scanner door so it won't flip open and listen for anything rolling or loose inside. It just might be your problem.
Dec 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
Clean the rubber rollers with a diluted alcohol and wipe down. They get dirty all the time and you could also have a piece of paper stuck inside too.
Aug 23, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Align cartridges
Hi ,
can u cet alignment print from u r printer if u get this printer .
please put this print on scanner & press scann button for scanning ........it will automaticaly align u r cartridges & printer will get ready for printing ......
if this information is useful for u please Rate me...........
if any update give me comments for it....
thanks & regards
Sandipk
Jun 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
