Question about AOpen AX45-V (91.88I10.004) Motherboard
Underclocked with my new processer
I bought a new processor which is clocked at 2.66GHz, i put it in and its working fine. Until i learned that its actually UNDERCLOCKED and going only as fast as my old processor which was 1.99GHz.
so basically my processor is only going 1.99GHz instead of 2.66.
I took the battery out of my Motherboard to clear the CMOS, no luck.
I flashed my BIOS, no luck
The exact problem lies within my FSB settings which i CANNOT access in my Bios.
According to Everest my motherboard is Aopen AX45-V Bios version R1.10
My processor is a Intel Pentium 4 2.66GHz
Also according to Everest my CPU FSB is 99.6 MHz (original: 133MHz)
so its underclocked.
I've already posted my problem on about 4 other forums and this problem is really getting to me, and i'd really like some quality answers so i can fix this. Any help is greatly appreciated
Thanks..
it seems the AX45-V doesn't have any FSB/Voltage feature, is there any way i can access this?
  • 781 Answers
Check the motherboard for jumper settings to change clock speed etc as usually if its not in BIOS its on the M/board
Posted on Aug 25, 2008
After each use, microwave clock disappears and microwave will not work until clock is reset. The clock will not allow itself to be reset unless we reset the circuit break which was not tripped.
Sounds to me like a fault with the main circuit board. Lets say the microprocessor on the board is bad and it locks up or just doesnt display the clock or time. When you reset the breaker you are resetting the main board. and it works until the processor fails again. Sound like may need new main PC board. Timer board. Caution!! Pricey??? Check cost of board before persuing, may be more wise to replace unit. and get new full warranty
Oct 13, 2017 | Microwave Ovens
My amd athlon II x4 640 only showing a clock spead of 783mhz, it is rated for 3.01ghz, how do i fix this?
somebody or something has been playing with your over clocking settings and has effectivly underclocked your pc as with what you have said it does not sound like you know much about this kinda stuff so i wont guide you through a bios incase you do something and i get the blame lol....what i need you to do is either reset your cmos if you know how to or take your power cable out and see the little watch battery on *********** board remove that and wait 5 mins and put it back in this will reset your cmos and recover your bios settings back to the normal and give you the power back
or you can go into your bios all bioses are different i want you to go to the end roughly and go to restore to default or optimised settings as i say i cant see it so it can always be different but it will be default settings or optimised settings or similar but if youve got no idea atall just take the battery out of the motherboard and this will reset the bios to when it came out the factory dont worry it wont reset anything to do with your actuall operating sytem......either remove the battery to reset cmos or give me your motherboards name and model and i will give you instructions how to reset the bios but as i said the best way is take the battery out when the power is off
Feb 24, 2011 | Advance AMD Athlon II X4 640 3 GHz...
I need just the lid. dlc-194tx. please help
There is a small plastic piece on the lids 1-196 that slides into a slot in theback of the processer and is s safety interlock. unless your new lid will fit into that it will nto work. I know because i bought the wrong lid after the exact plastic piece broke on my original and I could not get the new one to work... right now my "work around" is to put both lids on.. the newer one does have the piece but its it the wrong place and I have to hold them while I use the processor.. sorry
Jan 30, 2011 | Cuisinart DLC-1 Mini-Prep Food Processor
Can i run windows7with Gigabyte D525T-UD Mini-ITX Motherboard also cant get ddr3 800 memory have to get ddr3 1600 and UNDERCLOCK them in the bios how do i do this
Yes, you can, just that it will be really slow - the Atom processor is extremely weak. Just put the 1600 in, they will be automatically underclocked to 800.
Jan 18, 2011 | Gigabyte GA-D525TUD Atom Dual Core D525/...
Motherboard ID 07/28/2004-KM266-8237-6A6LYM4BC-00 **Above mentioned is the motherboard id of my motherboard. can u please tell me how much of the DDR can i use on my board? m using now one 512mb and...
Maximum of 1 GB per slot.
Yes, you can buy DDR400, it will be underclocked by the motherboard to DDR266. If you want some extra performance you can go in the BIOS and lower the timings one unit.
Yes, they will work, but not very fast. They should be used only as a last option.
Aug 03, 2010 | MSI Computers & Internet
I have motherboard ms8137c with cpu 1.6 ghz but it works like on 950 mhz, what sould i do to repair that
All Athlons were until a few months ago named on a power rating, not actual CPU speed rating. Since you didn't tell me the exact type of your processor i believe that it's the actual , normal speed of your CPU. But if it isn't then it's underclocked. To verify that go in the BIOS and see if the FSB is the correct value - 133MHz - sometimes it's at the default value of 100MHz. This can be changed from 2 locations:
1 - the JP4 jumper on the motherboard - 2-3 corresponds to 133MHz (of course you should change it only with the pc is disconnected from the mains)
2 - in BIOS go to Frequency/Voltage Control - CPU Host Clock and set it to 133.
Mar 24, 2010 | Matsonic MS8137C Motherboard
Launching apps like explorer is slow since I changed MBD Web brousing is slow. It paints screeen slow
It's possible that the default settings on the motherboard have underclocked your processor. Check the properties on My Computer to see if your processor is correctly identified. If not, reboot and go into your BIOS settngs. From there you should be able to properly clock the motherboard to identify your processor. If this doesn't apply or doesn't work, you can try flashing the motherboard. Hope this helps with your issue. All the best!
Greg
Jun 12, 2009 | Matsonic MS9158E+ Motherboard
I put a fresh battery in my new wall clock and it wont work
had the same problem myself. make sure that the hands of the clock are not bent inwards as to touch each other and get stuck.
my ones wre bent , a simple straighten solved my problem and the clock then worked fine. hope this helps
Apr 05, 2009 | Watches
Want to make a Presentation on all type of Processors
search in google.com for example "Intel Wiki"that will provide you with the most info about intel cpus and there is "AMD Wiki" that will bring up info links for amd cpus
Aug 01, 2008 | Computers & Internet
Gateway gt5648e desktop power
Do you know what your system is having the Processor error if you on the system the keyboard flickers and later go away but the fan also runs for seconds and later went off then what you have to do is to detached all components attached to your system then only the system unit alone .
Use a good power connector cable and a good constructed socket then put it on and wait and hear the sounds it brings and the signals or error is going show then if it comes on and go off remove the fan and replace with new one if the problem persist then change the processor with new one and then your system should be back to life and if anything happened then post your difficulties so i can help you. ok
rate this solution.
Jul 01, 2008 | Gateway GT5408 PC Desktop
AOpen AX45-V (91.88I10.004) Motherboard Logo
165 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
