Question about Intel Motherboard
E machine my computer will shut down and then I can't reboot it or if I turn the computer off it does the same thing it just displays the monitor setting after a while I keep turning off and on the computer and it will eventually load windows.
  • 781 Answers
Do you have a USB device plugged in and turned on If so tour BIOS is searching for hard drives and it takes time to find them
Unplug or turn OFF all USB devices until you have booted
Posted on Aug 23, 2008
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
Hi there. I have just purchased a new ASUS Radeon 6770 graphics card. I have just installed the hardware. When I turn the PC on, I can't get any video signal output from either the onboard graphics, or...
Hi granttoolmad
Shut down computer and disconnect power plug . Extract new graphics . Reconnect and reboot computer , you should get video back . Install the driver with the cdrom you purchased with the card . Shut down . Install new card . and boot your machine . Wait for Windows to recognize the card . Shut down . Connect your monitor to new card . Reboot .
Best regards ,
fanaudi .
Jul 04, 2011 | ASUS Computers & Internet
Monitor goes on and off........seemed to come on for the xp boot, but then disappears or is intermittant when the xp login page appears. Only fix sometimes is to reboot the computer. Very strange. Only...
In your Windows XP
  1. Go to Start and click
  2. The Start menu will open
  3. In the start menu click settings
  4. In the settings select "Control Panel"
  5. The Window of control Panel click "Power Options"
  6. In the Power options you will find Display time settings. These are the time settings that determine the time like if your computer stay idle for 5 min, the display will shut down.
  7. I suspect that this time is set to be very low like if there is no activity on the computer such as key punching, typically happens when you are reading an e-book Windows will automatically shut down the display. So you can increase the idle time to say 7-10 minutes and/or a similar setting is "Put the computer to sleep". Try to carefully alter the time values and you will find a good settings that work for you.
If the above tip does not work then there is definitely something wrong with your monitor's hardware most probably the power supply. You need to check it with a repair shop.
Good Luck!
Dec 09, 2010 | Xerox XG-71D 17" Flat Panel LCD Monitor
Monitor worked last night, now its black. if i turn off the monitor and then back on the screen comes ip for 2 seconds and then goes to black. Do i need to replace my monitor? my vidio card? or my...
Reboot into safe mode, go to the control panel > device manager (in xp the device manager is in the system folder) scroll down to display adapters, try to roll back the driver....the driver may have updated last night and the new driver is not compatible. After to roll back the driver, reboot the machine and see if it updates to another driver that is stable.
Oct 16, 2009 | Computers & Internet
E-machines monitor shuts down
go into the control panel and into the power options and make sure that the hard drive doesn't shut off and that the machine doesn't go into sleep mode and see how that goes.
Sep 03, 2009 | E-Machines eMachines Monitor E15T4
Hannspree 19" HF199H LCD - Display is LARGE on monitor!
Try Control Panel - Appearance or Display- You can change how your 2nd display looks there.. Sounds like you have it set in Clone mode...(both displays show the same things)...See if you can reset the 2nd display resolution while keeping the laptop in its normal resolution. Not all machines can do this...but most recent ones should be able to.
Mar 27, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Rebooting .. no effect on the monitor black blinking yellow light
Hi.
This is a hardware problem. If the machine seems to startup normally (apart from the monitor), then it is commonly caused by the video card coming loose. Turn it on, wait about 2 minutes until the drive activity dies down, then press the power button on the computer once. If the machine shuts down and turns off, then it had booted into windows normally and your data should all still be there. If you have a video card in the machine, unplug it, then re-seat it firmly and try again. If the machine is not booting (it doesn't shut down and turn off with a press of power), then unplug the RAM and the video card and press them back in firmly.
Mark
Mar 14, 2009 | Gateway Computers & Internet
Acer AL1711 17" LCD Monitor goes blank without warning
The need to reboot your computer to get your monitor working places the blame totally in the computer. You have a virus, or the computer is overheating and shutting down for thermal reasons.
-CharlyV
Jan 26, 2008 | Acer AL1711 17" LCD Monitor
Dell 2407 a04 Turns on (for 2 seconds) then off
your pc may be set to a resolution that is out of range for the monitor. Boot into "Safe mode" reset the Display settings to 640 x 480. reboot into normal mode then change the screen settings to your desired resolution.
Sep 07, 2007 | Dell UltraSharp 2407WFP 24" LCD Monitor
Problem when turning monitor off
mcdevito75 here LCD, or liquid Crystal display, chances are the crackling is the inside liquid display trying to capture the in comming electricity to make a display picture. Remember even an LCD is nothing more than a light bulb, a very intricate light bulb but a light bulb, and you have light bulbs burn out when you put them on and almost never as the are on burning. Turning the monitor itself off won"t really save electricity or the monitor itself as, when you shut down the computer from Start (left side of screen) the monitors screen saver comes on for 10--20 minutes then goes off, at this point the electricity is at the monitors on/off switch and not going thru the monitor at all. If you turn the monitor off at it"s on/off switch, the sudden jump of electricity to the monitor from it"s on/off switch could hurt it, or even the switch. I have a friend who turns off the monitor also and that friend had a bad monitor in 3 years. I never turn my monitor off just the computer itself. I'd speak with a Radio Shack, Staples, Best Buy ETC. for more advise. Me I;d say leave the monitor on. Hope this helps.
Mar 27, 2007 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Intel Motherboard Logo
24 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
