Question about RCA F27442 27" TV
Loose cable connection plug
My tv's cable connection must be loose because the cable keeps going off as if there is not attena or cable hooked up.;
Can that be fixed ? as this stv has a really good picture and I am wondering if it is worth it to get it fixed.
thanks
Vmundy2@yahoo.com
  • wild dawg Jan 05, 2009
    I have a RCA 36" TV with same problem. I thought it was the cable line but its the connector on the tv itself. How do you fix the connector on the TV ?
    President:
  • 1,952 Answers
Tv back cabinet to second hole to fixing cable hooked
Posted on Aug 23, 2008
If the coax input on the tv is loose your never going to get a good connection because its barely recieving the signal. If the coax input on the tv is strong and does not move back and forth even a little then its probably the cable box if not hooked up to a cable box then call the cable company and they need to figure out why your not getting strong enough of a signal.
Posted on Apr 25, 2009
HOW TO HOOK UP HDTV ATTENA TO DAYTEK 426F SO IT WILL ACCEPT CHANNELS
If your Daytek TV is equipped with a digital tuner, connect your HDTV antenna to the antenna input of the TV.
Feb 05, 2015 | Televison & Video
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Dvd is playing movies in black and white
Hi
use red/white/Yellow cables to connect to a loose hard diskon which I keep films, TV-serials and talking books. The colour is fine.
But I connect the DVD to the TV with a scart cable.
Hope you get your colour
Kolbrun
Feb 26, 2012 | Apex Digital ADV3800 DVD Player/VCR
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
Whehe do plugs go on back of unit? have direct tv
First off, you need to hook up audio and video by using an A/V cable to connect the DVD player to the TV, yellow, white and red jacks are coded, match the jacks up, put one end of A/V cable to DVD player OUTPUT jacks and the other end to INPUT jacks in back of TV. Also same with Direct TV receiver, hook top set of jacks to TV, with A/V cable, also connect coaxial cable from satelite to matching satelite input jack. Connect power cables, and then you're set. Good luck to you!
Dec 12, 2009 | Televison & Video
Can not get audio from tv to receiver
You may need to assign the optical audio input to the selected source. Also check to see if the input mode for the selected source on the receiver is set to Auto or Digital.
Sep 29, 2009 | Denon AVR588 Receiver
Cable attena
how do oi switch the tv from attenna mode to receive cable channels
Aug 11, 2008 | Durabrand DWT1905 TV
RCA F36676ETFM2
it sounds me that it is due to cable wire connection where it is connected is probably might be loose or if you have cable box there is some loose connection.
Oct 05, 2007 | RCA F31672ET TV
Tv attena
check attena connections if these are ok try retuning tele
Sep 20, 2007 | Panasonic CT-32SL14 32" TV
RCA F27442 27" TV Logo
1,068 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
