Question about Brother Office Equipment & Supplies
Sending an international fax with a brother fax machine
Hi there
I'm having alot of difficulty trying to fax overseas. From where I am (Australia) I type in 0011 63 (area code of destination) 2 (local area destinationa) *********
But even after putting it into overseas mode, it still doesn't work. I am thinking how to put on the + sign infront of the number. Could that be the problem?
Your response would be appreciated!!
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
I'm thinking you did not specify 1 for long distance and international calling check the TX settings for international and long distance
Posted on Aug 25, 2008
I want to buy a brother pc-420 in australia, how do i achieve that?
I suggest to ,, on the internet look for sewing machine shops in your town in australia, & even look in the phone book in the yellow pages
do you have a hancock fabric in your area? they have sewing machines & sergers
Feb 11, 2012 | Brother PC-420
Sending a fax to another county is easy - almost as easy as sending a fax to someone in your own country. The only difference is the phone number that you'll dial.
When sending a fax from one U.S. city to another, you dial a 1, then the area code, then the seven-digit phone number. When sending a fax from the U.S. to another country, you usually dial 011, then the country code, then a city code (which is like an area code), then the phone number. (The phone number isn't necessarily seven digits.) Check out the web site, which will give you the specific country and city codes for the place that you're trying to send a fax to.
Other than figuring out the phone number, faxing internationally is identical to faxing domestically. Fax machines in other countries use the same protocols as ones in the United States, so you should have no difficulty communicating with a foreign fax machine. Older fax machines and noisy overseas phone lines may cause the transmission to take a bit longer than you're used to, but it should get there.
The first time you send a fax to another country, it might be a good idea to listen in as the fax machine dials. On some fax machines, you can press the "Dial" button to hear the dial tone, and dial the number manually. Listen for the ring and fax tone, then press the Start button to send the fax. You might want to do this the first time you send a fax overseas, just to make sure it's working as expected.
Oct 06, 2010 | Office Equipment & Supplies
What is a Comm. error 2001?
This is an error message you get because of poor line conditions, this is common when sending overseas.
Please follow the directions below for sending overseas.
Press (Fax). Load your document.
Press up or down arrows to choose
Overseas Mode.
Press OK.
Press up or down arrows to choose On (or Off).
Press OK.
then dial number and press start.
Apr 12, 2010 | Brother MultiFunction Center MFC-440CN...
My machine will not fax overseas
Be certain that you use the code for international calling, that your FAX line can support international calls / faxes and that you have selected Overseas Mode.
Hope this helps.
Mar 27, 2010 | Brother IntelliFAX 2800 Laser Fax
Brother mfc640cw
If you are having difficulty sending a fax overseas due to possible
interference on the phone line, we recommend that you turn on the
Overseas Mode. After you send a fax using this feature, the feature
will turn itself off.
1 If it is not illuminated in green, press (Fax).
2 Load your document.
3 Press Menu/Set, 2, 2, 7.
4 Press ▲ or ▼ to select On (or Off).
Press Menu/Set.
Your manual gives this information also on page 3-13
Good Luck
Dec 15, 2009 | Brother MFC-640CW All-In-One InkJet...
International Faxing??
you need an international phone service and dialing capability on your phone, the country code for Australia is 61 so you would dial:-
011-61- Y- xxxxxxxx where 011 is international code from USA, 61 is country code Y is area code and xxxxx is fax number.
Just dial the number as sending a local fax
Dec 15, 2009 | HP 1040 Plain Paper Inkjet Fax
I need a fax sending from australia to england but unsure what the international code is for faxing and what numbers too take out, the uk fax number is 01803 521785....please help?
A fax is nothing but a normal homestyle phone line. Either go online to find a list of country codes or call your local operator for assistance.
Sep 22, 2009 | Office Equipment & Supplies
Calling overseas from Australia to UK on a Uniden 9035 handset
Just dial 0011 then the country code. The + is just a quick way of dialing 0011.
Also these can be used from Australia 0011 (Voice calls)
0015 (Fax calls - Telstra)
0018 (Telstra special rates)
0019 (Fax calls - Singtel Optus)
go to full a full list of international codes
Dec 01, 2008 | Uniden Cordless Phone
Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
May 27, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Sending fax
Oct 02, 2007 | Brother IntelliFAX 4100 Laser Fax
377 people viewed this question
James Cagle
James Cagle
Jim Keysor
