Picture has vetical lines - Televison & Video
    President:
  • 1,952 Answers
Go to menu and setting
Posted on Aug 23, 2008
White line in center..sound iis fine
Most common are soldering problems on the vertical deflection IC's.
If this line is quite bright: shut down the set, it might damage the picture tube permanently. Resolder all pcb connections under the vertical defl. part. With a magnifier you can see "craters" around the footprints. Where is the vert. deflection. ? Mostly an integrated circuit
on a vetically mounted heatsink . Typnumber: mostly something TDA53xx like. Gently knocking with a screwdriver and observing the screen might lead you to it's location if you're not familiar with TV's.
Watch out: lethal voltages !
Jan 27, 2014 | Panasonic CT-32SL14 32" TV
Horizontal line running through the middle tv screen, no picture but has sound. TV is a Toshiba.
You haven't vertical deflection.
The ff caused the problem.
1. Dry joints on the vetical section.
2. Blew Vertical ouput IC
3. Open yoke vetical winding.
4. No vertical output from jungle IC.
5. Open supply for vetical ic due to open fusible resistor.
I've suspect that you have #1 and #2 fault. This is not Diy so I've advice you to send to repair shop or look for a qualified tech to isolate the problem.
Thanks for using fixya.
Jan 26, 2011 | Toshiba Televison & Video
Horizontal line. When TV off for about 3-4 days & I hit it, then the picture comes on. I had this problem for over a year. Is the picture tube gone?
No this is not your picture tube causes you that king of problem.
In fact this is only due to a dry joints on the vetical output ic.
Resoldering the cold solder will fix the symptoms.
I've advice you to look a qualified technician to resolder the said parts.
This is quite fixable.
Pls rate my help.
Jan 19, 2011 | Panasonic CT-35G25 TV
Vetical lines appear & a horrible noise, have 2 reboot numerous times per day gateway P-6822 series
Vertical lines are usually caused by an lcd hardware problem.
Can you boot the computer to an external monitor?
Do the lines appear immediately after starting the comptuer?
Nov 29, 2009 | Computers & Internet
Will not turn on. Shuts off immediately after turning on.
Sounds like the vetical deflection went out. Most likely have a leaking picture tube and the cooling fluid has goton on the board so you would be beter to replace if that is it.
Sep 03, 2009 | Mitsubishi VS-55707 TV
Vetical and horizontal lines on screen when recalling picture
it is a possible CCD FAILURE !
u are covered dont worry it is a manufac fault inn CCD's Fuji will do it Free of charge pls see the link www.fujifilm.com and call them and PLS RATE ME FIXYA for help
http://www.imaging-resource.com/badccds.html
dont worry if u are not on list just call them !
pls dont forget to rate me
May 07, 2009 | Fuji FinePix F10 Digital Camera
Black vetical lines on the screen. how do u fix
You need to flash or update your computer's bios. if you have an inspiron 1501 go here:
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R174470&SystemID=INS_PNT_1501&servicetag=&os=WLH&osl=en&deviceid=13120&devlib=0&typecnt=0&vercnt=9&catid=-1&impid=-1&formatcnt=1&libid=1&fileid=236967
read the installation instructions or print it. then download the file and follow the instructions. after restart. see if you still get the vertical lines.
Mar 02, 2009 | Dell Inspiron E1505 Notebook
Mitsubishi projection #vs-50707
gud day.. you need to bring that on the shop.. there is a problem in the PCB, particulary in its vetical section.. .. if you continue to used that, the problem become bigger..hope i help u w/ ur probs..ty
Mar 08, 2008 | Televison & Video
Proview 700p problem
DISPLAY IS GOING OUT SIMPLY GET NEW MONITOR
Jan 16, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
No clear picture just wavy lines and error message
The spec sheet I found says your monitor should be able to display 1280 x 1024, 720 x 350, 720 x 400 and four other resolutions in the 640 x .... range which are pretty useless. Try setting ti to 1280 x 1024 at 16 million colors @ 60 Hz and let us know what happens.
Nov 26, 2007 | IBM 9516 Monitor
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
