Question about Ricoh Aficio 2020 All-In-One Laser Printer
Ricoh AF-2020 SD problem
Facing problem in one Ricoh machine model: AF-2020, printer is not working due to SD memory card.
Is there anyway to solve it without replacing the card.
How can i get drivers fore this printer
Posted on Sep 08, 2008
How I can replace the memory card?
Get printer box on the side where you connect your LAN cable you will find some SD ram slots it has one screw open and slot your card in while the machine is switched off
Jul 22, 2014 | Ricoh Aficio 2027 All-In-One Laser Printer
Paper jaming in ricoh af 1022 in adf
Paper jams in Ricoh Adfs ( or others), generally have origin in dirty rubber rollers. Oh yes, they can look clean but try to wash them with Benzine and check the cloth! You have to have full traction between the rubber and the paper , otherwise they skew and jam or are not picked up even. Other problem is in the exit (lower ADF side) , a misalignement between adf and the machine body. This can be solved with the mounting screws in the Adf back. Dont forget to have the paper format sensors (top right of ADF) clean and last, you may want to check the horse shoe sensors INSIDE (rear cover ADF). In my lifetime as a Ricoh tech, it only happens this once, and because the machine suffered ADF damage due to Portuguese bumpy roads, Ahahah. I am excluding the obvious, such a paper clip, a stapple, a coin , etc.. This happens very often...
Feb 22, 2014 | Office Equipment & Supplies
I have af 2035/45 ricoh i am facing paper jamming at exit unit. i have done replaced sensors and bicu board and check all related wiring, but couldn,t find solution.
paper jam in aficio hasnt reset . but you must check all doors .it may be one door in your machin is open .more than more right door check it
Apr 27, 2012 | Ricoh Aficio 1035 Copier
Printer network setting error message
SmartDeviceMonitor for Admin SmartDeviceMonitor for Admin is a Windows utility software that simplifies all aspects of installation, monitoring, and management of network devices. SmartDeviceMonitor for Admin tells you precisely what printers are available, how they are configured, even toner and paper levels.
Apr 18, 2012 | Ricoh Office Equipment & Supplies
Ricoh 3045 say's cannot instal the software when i insert the SD card in it
go to Sp Mode, select 5 number option which is known as mode. now choose 2nd last option which is (for NIC) press 1 and then press # similarly (for USB) press 1 and Press #, now simply reboot this machine.
Regards;Noor Impex151-Naiper Road Mall Road Lahore+924237232511MAJ
Mar 22, 2012 | Ricoh Office Equipment & Supplies
I need aficio af 2020 software and driver to download
To download the driver for Ricoh Aficio 2020 follow these .steps :
1. Go to the link below
Driver download for Ricoh Aficio 2020
2. Select your operating system from the given list.
3. Download the required driver software.
Nov 17, 2010 | Ricoh Aficio 2020 All-In-One Laser Printer
Mpc 1500s sc 202 and af 1075 sc 995
are you sure the codes SC202 is ink related and you need to check the covers on the cartridges as the ink has run out...or the head is not recognising the cartridge..
the sc995 is due to a NVRAMM missmatch or failure.. the serial numbers are not recognised.. if you have replaced the controller board it is not correct or faulty. you can get a sd card and do SP5825 to download new details to the new NVRAMM
Jul 10, 2010 | Ricoh Aficio 1035 Copier
Ricoh Aficio 2020 All-In-One - printer offline
Under printer check book unmark Use printer offline
Nov 23, 2009 | Ricoh Aficio 2020 All-In-One Laser Printer
Network printer installation problem
Are you using the proper Windows Vista Driver? You can't use the XP's a link to the download page:
Jul 11, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh Aficio 2020 All-In-One Laser Printer Logo
697 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
