Question about Samsung CLP-300N Laser Printer
Samsung 300n Hello My samsung 300n black toner cartridge is streaking something fierce any suggestions would be appreciated
  • 97 Answers
You will need to replace the developer unit of the printer. It is a consumable item in this printer.
Posted on Aug 27, 2009
SOURCE:
Hello! My Samsung ML 2010 Laser Print has started to print pages with streaks of ink across them. This makes the pages more difficult to read, and certainly cannot be used for formal letters. It also...
there must be waste toner in your toner cartridge
the waste toner box is fitted above the drum in toner cartridge with 2 no screw open it and empty then try to print
Jan 26, 2011 | Samsung ML 2010 Laser Printer
What causes a white streak and faded print to appear on copies?
Most often on the PC940 this means your toner cartridge is getting low on toner. To prove this is the cause, just remove the toner cartridge and while keeping it relatively level, shake it side to side a few times. This will re-distribute the remaining toner in the cartridge. Re-install and make a copy. The black streak/faded copy should be much better. If so then I would go ahead and get a new cartridge on the way.
Thank You for using Fixya.
Testimonials are always appreciated!
WheatlandServices
Oct 21, 2010 | Canon PC-940 Black and White Copier
Printing a large black streak of toner on rt side of page
Hello! Malik Muhammad Mehran Here... your problem solution is that you must replace the cleaning plates in the cartridge...
Mar 28, 2010 | HP LaserJet 6L Printer
Samsung CLP-300N printer shows faint banding
Developer roller worned,common problem.roller can be changed,take drum out,2 screw 1 on the side near toner excess bin and 2nd on roller.
Jun 24, 2009 | Samsung CLP-300N - - color - laser -...
Black streaks on paper ML 2150 laser printer
Black streaks usually mean that toner is baked on. Pull out the old cartridge, if it has a lot of toner, vacuumn it out (unplugged of course), and then replace it with a new cartridge.
Apr 28, 2009 | Samsung ML-2150 Laser Printer
Black streaks on paper on samsung ml 2150 laser printer
Could you describe these marks for us please.
Are they small specks or blotches? Bad Toner Cartridge
Are they lines:
Horizontal - Transfer Roller or Charge Roller
Vertical - Bad Toner OR Bad Fuser.
Note: A bad toner cartridge can render all of the parts listed here useless. Check for build up or lines on the cartridge reflective drum. Avoid light, as with film.
If they are a mix of both, the device needs to be cleaned with a can of compressed air. You must remove the cartridge, paper tray(s, and fuser to create clear path.
Apr 28, 2009 | Samsung ML-2510 Laser Printer
My Canon PC-25 copier is streaking
Toner cartridge is defective - replace it
Apr 06, 2009 | Office Equipment & Supplies
SAMSUNG CLP 300N prints poorly after replacing toner cartridge
This is a fairly common problem, caused by a faulty black developer roller. I spoke to Samsung about mine, when it was 1 day out of the warranty and explained it started happening three weeks before (which was true). It had about 1,300 page count, when fuser kit should last 20,000. An engineer visited next day and replaced the roller, as well as a cautionary replacement of the paper pick-up rubber. Print is back working fine now. Chatting to engineer, the rollers have been modified now, so the fault must be causing concern. He said he's got another ten coming in stock tomorrow. Keep the previous toners, as they will still work once printer is fixed. I must say, Samsung support is excellent (the reason I bought from them!), so speak to them and so what they will do.
Nov 24, 2008 | Samsung CLP-300N Laser Printer
CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
Jun 12, 2008 | Samsung CLP-500 Laser Printer
Samsung CLP-300N Laser Printer Logo
67 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
