LG50P3CD Plasma television - remote control will not power up the television / function....but will work other components of av system...
  • 1,952 Answers
Use spare remote or use new battery
Posted on Aug 23, 2008
What component controls the power switch for a Philips Flat Plasma TV, and can it be replaced?
Its main system control IC controls all functions of the TV. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Aug 01, 2015 | Philips Televison & Video
How to connect viera link
What is Viera Link? Viera Link allows the control of other Panasonic home AV devices via the television remote control.
By pressing the Viera Link button on the television remote, it is possible to turn on and navigate the menus of other Viera Link equipment. Please note, Viera Link requires an HDMI connection between the television and the external source.
More control functions have been added with each new generation of Viera Link compatible products. However, it is important to note that the newer functions only work if both products are from the same year of manufacture. Therefore, if an older source is used with a newer year of television, only the older functions common to both years will work.
Aug 26, 2014 | Panasonic Viera TH-42PX80U Plasma TV
Cant change from av to any input
First try a simple "reset":
1) Turn TV off. Unplug all TV inputs, and the AC plug from wall. Wait 5 minutes (I mean it, a full 5 minutes!).
2) Connect your normal TV source (cable or satellite) ONLY, then plug in and turn on the TV.
3) You may need to press the RESET key twice after connecting the signal and turning on the DTV to restore some functionality.
Now plug in ONE A/V component at a time to test. You can also try replacing any A/V cables (RCA red/yellow/white, HDMI, etc.), as cables do occasionally go bad.
Make sure TV is "tuned" to channel 3 before pressing the "input" button on remote control This is easiest done with the actual channel up/down buttons on the front of the television itself, or possibly by pressing 03 (or 03, Enter) on the remote control.
You may find that only one A/V input is bad (ex, VIDEO 1 port), while others work.. or they may all be bad.
If other functions of remote control are working (but "input" button still does nothing), could simply be a bad remote. Try eBay for a cheap replacement.
If there is not a manual "input" button on the TV itself (I think not for this particular model), and you still can't change AV input, you are probably out of luck. I recommend read included instruction manual carefully, then contact the manufacturer if needed. Instruction manual may be viewed at:
Do not attempt to disassemble TV. There are no user-serviceable parts inside, and even an unplugged TV can retain enough electricity (in capacitors, etc.) to seriously hurt a non-trained human. This TV is probably ~ 9 years old; parts are available (eBay, etc), but may not be worth fixing considering huge price drops on new TVs available now.
Mar 07, 2014 | Sanyo DP42746 42 in. Plasma Television
Sony AV STRDE475 remote altenative replacement
The assistant is right. It will be best to buy a new original remote control. In most cases a universal remote control won't function to all system. You can get the original one from the Autorized service center for Sony. If you wish to get more details about the set-up codes to different other universal remote control, check this link. Pull up older posts by its sidebar. Set-up code list and proceedings to many popular remote controls are given in detail. Choose one out, which has set-up codes to Sony brand TVs, and the availability.
Jun 16, 2013 | Televison & Video
How do get the AV port without a remote control?
One of the buttons should have this function just try them all and see how you go. I have done this in the past.
Sep 25, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Need universal remote control code for maxent 42" plasma tv?
I hope that you have gotten this resolved, but if not, or if you have any other questions, here are the codes and some simple steps to run through.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
Becki Barned
DISH Network Customer Service
May 17, 2010 | Sampo PME-42V3 42 in. Plasma Television
My Sony remote is RM-YD024 - I am trying to find the code for a Denon DVD player, Norm.
Here are all the codes for your Denon DVD player.
30490, 30634, 31634
Just in case you don't have the manual I also included the steps to input the codes.
Hope this helps
Follow these steps to program the remote control.
NOTE: Even though the FUNCTION buttons are labeled for specific components, they can be programmed to operate any type of equipment that is compatible with this remote control. For example, the BD/DVD function can be programmed to operate a VCR, AV receiver, etc.
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the INPUT button.
  3. While holding INPUT button, press the FUNCTION button for the desired component.
  4. Release both buttons.
  5. NOTE: The FUNCTION button will blink for approximately 30 seconds or until a code is entered.
  6. Using the number pad, enter the component's manufacturer code.
  7. NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
  8. Press the ENT button.
  9. NOTE: The FUNCTION will blink twice if the programming is successful, if not, it will blink five times.
  10. Point the remote control at the component.
  11. Press the component POWER button to verify operation.
  • If a new code number is entered, the code number previously entered will be erased.
  • When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
  • Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, use the remote control that was provided with the equipment or purchase a universal remote control that has a learning function.
  • If programming fails, it may be necessary to reset the remote control. To reset the remote control, remove the batteries and press each button on the remote control twice.
Nov 04, 2009 | Sony Televison & Video
When i press av on my remote control i have tv ext and digital options but where has the options for ext2 and 3 etc gone
Dont know your specific model, **** some new tv's will only allow access to av inputs that is connected with cables and a component. Move your cabling from ext 1 to ext 2 or 3 and see if you can access the av ext. If still no access on ext 2/3 the av input board or backup memory could be faulty.
Aug 10, 2009 | Philips 42PF7220A 42 in. Plasma Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
