Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
WON'T TURN ON
I PUSH THE POWER BUTTON AND THE SET WILL NOT TURN ON. THE STANDBY LIGHT FLASHES NINE TIMES THEN STOPS THEN FLASHES NINE MORE TIMES ETC. SOMETIMES THE TV WOULD TURN ON AFTER PRESSING THE POWER BUTTON SEVERAL TIMES, BUT NOW IT WILL NOT TURN ON. ANY ASSISTANCE ON THIS PROBLEM WOULD BE GREATLY APPRECIATED.
  • 1 more comment
  • Anonymous Aug 25, 2008
    wont turn on
  • luberts7 Aug 25, 2008
    wont turn on
  • frankofelia Aug 28, 2008
    stand by blinks nine times and tv wont turn on
  • 125 Answers
Nine blinks means that there is a short inside the set you will have to find a tech to troubleshoot the set most probably is the G pcb
Posted on Sep 01, 2008
SOURCE:
How do I solve a problem with my Hp Probook, whenever I press the power button, the power light flashes nine times?
On that particular model you need to press the power button nine additional times waiting for the light to Blink 9 times each and then after the 9th time the procedure is as follows... Press the button 4 times hold for seconds on the fifth button push then release for 4 seconds then press the button twice and it should blink 8 times repeat this procedure continuously until the button only lights up once. After the button lights only once then you are ready to place the item into a garbage bag and throw it into the dump
Feb 08, 2018 | HP Computers & Internet
I can't descale my C5
You may need to go into program mode and "tell it" you replaced the filter. We normally do this when we replace water filters in Jura's. On the f60 you get into program and scroll using the water volume dial and push it in to set the changed value.
Hope this helps
Jan 25, 2013 | Jura Impressa C5 Automatic Coffee Center...
On/Standby light flashes red four times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 27, 2012 | Sony VPL-EX100 3LCD Projector VPLEX100
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron won't turn on - standby light blinks nine times
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts...
Apr 08, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Standby light flashes nine times and tv will not turn on
I had the same problem with Sony KV-32fs120 with 9 blinks. Replaced D645 and D647 on main board with 1.5A1KV diodes from Radio Shack which did the trick.
Jul 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
209 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
