Question about EliteGroup P4VMM2 V8.1 Motherboard
Checksum error Hi, Im Oliver, my computer give messege like this BIOS ROM CHECKSUM ERROR, what can i do? please help me>>
  • Anonymous Mar 28, 2014
    no boot
    President:
  • 2,351 Answers
Hi Oliver, the most common error related to the message,
(Bios Rom Checksum Error). Someone has left a floppy disk in the floppy drive. Once the floppy disk has been removed press the reset button on the PC, your windows will start normally. Next place to look is in your bios.
Open your manual to page 27.
Enter your bios & go to the title Advanced BIOS Features. Check First, Second & Third boot devices they should be as follows. Floppy disk drive, CD-ROM drive & primary hard disk drive. If both of the above are ok than try clearing the cmos/bios by resetting the cmos jumper (JP1) location on page 5. Descriptions of page five on page 6. CMOS settings on page 9.
When your system restarts re-enter your cmos & reset up your bios settings. Lastly if none of the above has fixed the error message, than remove the cmos battery & check its voltage. It should maintain 3volts. If yours' is lower than 3volts replace the cmos battery. There is one other possible fix. It’s an option not given lightly. Flashing a cmos/bios is not recommended unless all other options have failed.
Bios link for the EliteGroup P4VMM2 V8.1
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=436&DetailName=Bios&DetailDesc=P4VMM2%20%20(V8.1)&CategoryID=1&MenuID=82&LanID=0
Main web site;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=52&LanID=0
Good luck Oliver!
Mike
Posted on Aug 25, 2008
SOURCE:
I used jumper bios reset and now gettin bad checksum error. on the mother board writen that K8N rev 1.01 i downloaded k8n motherboard rom file and renamed as k8n.rom and copied to disket. its deleting and...
Hi.
The most probable reason you are getting the bad checksum error is you have to set the date and time because you have cleared the CMOS and reset the BIOS.
You should also get a message that says press F1 to load defaults or press a certain key to access setup. Access setup (BIOS) and set the date and time. That should take care of the bad checksum error.
Another good idea is make sure the motherboard battery is not dead either.
Regards.
Jun 17, 2011 | ASUS Computers & Internet
My computer beeps at start up
Depending on your beep code, this might be a hardware problem. Please refer here for a bit of details.
Hope this will give you a place to start.
Apr 26, 2011 | Computers & Internet
Can you please help me how to fix the BIOS ROM CHECKSUM ERROR. TO MY MOTHERBOARD (TRINITY 400 S1854 AGPX4-PCI-ISA) i reformat the windows NT version 4, and after i restart, the message come bios rom...
turn the computer off
now turn on and hold down the delete key until the bios screen appears
in the boot tab select first boot as the cd disk, install the cd for win nt in that drive
close down the cd and then restart and it will boot from the cd
BY reformatting the hard drive win nt you have wiped the win nt operating system from the hard drive
Feb 17, 2018 | Tyan Trinity 400 S1854 Motherboard
BIOS ROM checksum error
sounds like your bios is corrupted, try going to the motherboard site and update your bios software. It could also be bad memory modules.
Nov 01, 2009 | HP Computers & Internet
Bios ROM checksum error (Compaq SR5237CL with M2N68-LA MB)
A BIOS checksum error can be caused by a nearly flat BIOS battery.
I would replace the BIOS battery first before attempting to upgrading the BIOS.
Some motherboard BIOS firmware is upgraded by running a program that has been copy to a DOS boot disk or the upgrage maybe done from within the BIOS setup. These firmware upgrage and instructions are on the motherboard WEB site, in your case the Compaq/HP WEB site. Make sure you select the upgrade for your model motherboard.
NOTE it is possible that if you make a mistake you could ruin your motherboard, if you are not sure seek help from a computer savy friend.
Use this link :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Sep 17, 2009 | HP Computers & Internet
My computer can not boot -BIOS ROM checksum error
to be honest if you have tried to re-flash your bios, and it did not work you still either have hte wrong version or the disc drive your using to flash it from is faulty. try another floppy drive/disc and try again. if that dont work. to be honest it's not worth getting it repaired just go out and spend £30-40 on a new mobo. sorry i'm not more helpfull but i dont believe it's worth spending that much time and effort on an old system like that with this kind of problem. good luck to you. let me know how you get on ok.
Jun 15, 2009 | EliteGroup K7VTA3 V5.0 Motherboard
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
The rom you used to flash the bios may not have been the correct one for your mobo, or it did not complete the flash entirely. Try using the usb a drive to flash it again and/or revert back to an older version.
Aug 01, 2008 | Foxconn P4M9007MB-8RS2H Motherboard
Checksum error
Hi Faster Fester. You don't need to install the new BIOS.
You get the checksum error just because you're CMOS battery have run out. Just try to replace the CMOS Battery and you're problem will be solved.
Regards,
Grydor.
Feb 09, 2008 | Computers & Internet
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
EliteGroup P4VMM2 V8.1 Motherboard Logo
437 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
