Question about Samsung HLN567W 56" Rear Projection HDTV
Samsung hln567w Gray horizontal lines
Devices hooked up to any of the 3 Video inputs have light gray or hazy horizontal lines on the tv. I I move these to the component inputs or utilize HDMI, the picture is fine
  • jaashland Aug 23, 2008
    This problem is on a Samsung HLN567w DLP TV.
    President:
  • 1,952 Answers
Have you tried a system restore to get your resolution back?
You may then try to take a different path in fixing your problem.
if you cant system restore try installing the previous driver you had.
could you post up what your "computer problems" were exactly?
the more info the better*
We may know another solution for it other than updating your driver and losing you resolution options
Posted on Aug 23, 2008
Getting 3, 2" wide gray/black lines in screen.
Please answer the questions in video to yourself and then give a more detailed description, as there are many reasons depending on what exactly is happening. TV Repair Help for Vertical Horizontal Lines on Your TV Screen...
Nov 28, 2015 | Proscan 32LB30QD 32 in. LCD TV
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
I'm looking for a fix to my super nes. Whenever i connect the game to the tv and turn it on with a game inside all i see is large grey horizontal lines on the tv. The game cartridge works on the first try...
i have the same problem with the gray lines but mine blinks really fast and its extremely annoying. I think the problem is the tv you probably hooked up your snes to. I dont you which tv you hooked it up to but ive heard that if you use like a modernish tv, it will create those gray lines and the blinking so you should hook it up to an older tv. i dont no if this is true because i didnt switch my tv YET but hopefully, it will work better with an older tv. hope this helps ^_^
May 20, 2010 | Nintendo Super NES Console
Have Samsung HLN567W and recently started having
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 12, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Samsung HLN567W wavy lines
Check to see if your DVD player is outputing a progressive scan and turn it off if you are using the S-Video cable, it does not support progressive scanning.
Apr 18, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Horizontal gray lines in display screen and on TV
if u see them on lcd and final output also have these grey streaks then ur problem might be this u can call canon for free repairs but first try to clean ur camera head with head cleaning cassette and see if it helps otherwise call them see link
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
pls rate me fixya for help
Apr 07, 2009 | Canon Cameras
Lines on the screen whit audio and video imput.
You need to make sure that the inputs on the TV support the resolution that your DVD player is outputing - Component inputs 2 & 3 do not support 420i...
Mar 25, 2009 | Samsung HLN567W 56" Rear Projection HDTV
I have a HT3061P Prima TV. The screen is gray color with horizontal lines,the audo is very good.
check the RGB supply it is 180volts or the capacitor value 10/250volts (4.7/250v, 2.2/250v)
Oct 16, 2008 | Prima CV2011 TV
Samsung HLN567W 56" Rear Projection HDTV Logo
140 people viewed this question
Henry  Thomas
Henry Thomas
