Question about Panasonic PT-47WXC43 47" Rear Projection Television
Panosonic 50" LCD 1080i HDTV screen picture faded
White colors seem really bright, overpowering other colors to make the picture faded. Any Ideas? Thinking a new bulb, not sure. I know NOTHING about electronics.
    Sergeant:
    Champion:
  • 375 Answers
Try setting your menu;s to adjust the picture settings
Posted on Aug 23, 2008
Panasonic hdtv 1080i picture bright
It could be your main board going bad.
Jun 01, 2013 | Televison & Video
CONTRAST ADJUSTMENT
it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels.
I am further looking into ur problem..
Goodluck..
Feb 07, 2008 | Hitachi 57F500 57" Rear Projection...
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
I have my settings on sports for a high contrast and nice bright sharp color and in the last 2 weeks the color has gotten darker. Like the contrast is slowly starting to fade away. On blu ray movies the...
you have to check preset picture mode if still not good then reset setting in setup mode.after that your picture become good. if problem still then there is problem with LCD panel.
Oct 16, 2010 | Insignia 42" LCD Flat-Panel HDTV
Screen has too much green all of a sudden
Try balancing the tubes out, turn your color all the way down and the brightness in the middle, then find the focus block, it will be a block with 6 controls one row will say screen the other will say focus near the picture tubes, adjust the screen controls(one control for each color) until the picture has a good black and white look to it, then turn your color up and it should look fine. This is how i balance out the picture. But there is another method that allot of techs use, the other method is to adjust the brightness up until you see what is called retrace lines it is a jagged line going down the screen, once you see these lines back the adjustment down just until they disappear. Do this for all three colors. This method works but on an older set can throw the white balance off because of tube wear.
Sep 03, 2009 | Hitachi 57F500 57" Rear Projection...
Dont know the contrast ratio of this tv
Specifications
Panel Type: 32" Diagonal (31.5" Viewable), 16:9 Wide Screen, Color TFT Active Matrix LCD
Panel Specifications: Anti-Static and hard coated surface
Pixel/Dot Pitch: 0.507mm (H) x 0.5107mm (V)
Display Compatibility: HDTV (1080i)
Signal Compatibility: 80i (SDTV), 480P (EDTV), 720P (HDTV), 1080i (HDTV)
Response Time: 8 ms (typical)
Colors: 8 bit 16.77 Million colors
Brightness: 500 cd/m2
Contrast Ratio: 5500:1 Dynamic Contrast Ratio
Viewable Angle: 178° (horizontal and vertical)
May 23, 2009 | Vizio VW32L 32 in. LCD HDTV
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I GET WHITE SPOTS ON MY LCD SCREEN
this is a touchy subject for sony. basically sony has increased the brightness levels for the backlights to have better color tones in thier lcd's. well the downfall of this is the white spots you are experiencing. this is not a defect, you will never get them to go away, the only thing you can do is to turn the backlight and brightness down to reduce the white spots. if you contact sony, there is a software upgrade that will help reduce this issue...
Oct 17, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Open Questions:
Panasonic PT-47WXC43 47" Rear Projection Television Logo
188 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
