Question about IBM ThinkPad T41 2373 Notebook
Thinkpad T41/Windows Vista
I get a blank screen at startup after Microsoft Corp logo, power led stays on that is all, have checked the bios, used F8 to try last known good configuration. Cannot start in safe mode same blank screen, tried leaving it on overnight still nothing.
Recent history is I purchased 256mb ram giving us 512mb, then loaded vista, which has been running ok for 3 months or so, I then purchased a battery for it (we were running it off AC power only), after this we turned it on one morning and that was it, I have since tried without the battery and replaced the 256mb ram with a new one.
Now I have run out of ideas. Can anyone help please. My 10yr old is becming impatient.
Lor
    Genius:
  • 2,028 Answers
Your hard drive has failed and will need replaced. If it were a simple operating system glitch, you would still be able to get to safe mode. Purchase a new hard drive, load the system, and you'll be good to go.
Posted on Aug 23, 2008
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    • Search www.microsoft.com for terms in error message.
    • Search www.hp.com for terms in error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
      • Select Disable automatic restart on system failure to view error message.
      • Run Repair Your Computer .
      • Run Last Known Good Configuration .
      • Select Boot into Safe Mode and then select Run a Microsoft system restore .
      • Select Boot into Safe Mode and then select Uninstall recently installed programs .
      • Select Boot into Safe Mode and then run Windows Update .
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
    • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
    Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
    Oct 09, 2011 | HP Mini 1000 Netbook
    IBM ThinkPad
    this can be solved...can you boot to safe mode, through F8?
    Mar 07, 2008 | IBM ThinkPad T41 Notebook
    Tip
    Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
    <b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
    on Mar 08, 2011 | Computers & Internet
    IBM thinkpad t42 boot up problem.
    The sympton is rather vague, but I suggest the following options, to be followed one by one, until one of them works for you.
    1) Boot your system in Safe Mode (if Windows is your OS) by pressing F8 after the usual "beep" provided by the BIOS after it detects all is fine. If it boots up, which takes a little longer than usual, then your system is probably Ok, although it may have a configuration problem.
    Reboot the machine from the shut down menu and hopefully it will work Ok. If not, then, depending on whether you have Windows Vista (or better), try:
    2) Boot again pressing the F8 key, but this time locate the option that reads something like "Last known good configuration". Highlight it with the arrow keys and press Enter.
    If you have System Restore set on your drive(s) your laptop should boot up normally.
    3) The last option would be for you to go into your system BIOS and run at least a HD detection test, followed by a memory test, etc., but I would only recommend doing this if you know what you're doing. If not, ask a friend for help.
    Aug 17, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
    Hi, I have a ibm t41 and when I switch it on, it boots up to show the windows xp screen but will not do anything else. It will not load pages when I click on them or even the start menu when I click on...
    Try starting in safe mode, pess F8 continually at start up, then choose safe mode without networking. If you can enter safe mode, then go to start, run, and type msconfig, click on the startup tab, and disable all, then restart. This will turn off all of the startup programs and use less resources. If this works, I would then recommend downloading malwarebytes from malwarebytes.org and running it to clean the system of possible infections. Then, check how much RAM you have, you may need to upgrade. If you can't even boot into safemode, then you may need to reinstall the operating system.
    Vista on t41
    vista will work, no problem. But Xo will work faster / better.
    Jun 16, 2009 | IBM ThinkPad T41 2373 Notebook
    My Toshiba L300 satellite pro wont load up
    USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
    rapidshare.com/files/51117041/ERD-2007.rar
    IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
    May 08, 2009 | Toshiba Satellite Pro L300 Notebook
    Windows Vista not Booting Up
    1) Press and hold the power button for 10 seconds to turn off the computer
    2) unplug the power cable and remove the battery from the laptop
    3) Press and hold the power button while the power cable is unplugged and the battery is not connected so as to discharge the computer
    4) Place the battery back again and plug in the power cable.
    5) Look for the F8 key on the keyboard.
    6) Turn on the computer and start tapping F8. Do not stop tapping F8 until you get to a menu.
    7) Use the up and down arrow keys. Highlight Safe mode. Press enter
    8) Log in to system.
    9) Do a System Restore to the date before you left the computer.
    Mar 22, 2009 | Dell Inspiron 1720 PC Notebook
    Blank/black screen at power on
    This is hopefully a possible fix. I have encountered a similar problem with windows xp and vista. the fix I found that will eliviate this problem and a startup-reboot-startup-reboot... If you have your original windows (xp or vista) CD lounch it like you would do to do a system install. As the installation starts it will show ask you if you would like to do a recovery using the recovery console, just press ESC and go on. Press the F8 to accept the license. If Windows is not completly broke, it will find the original installation on your hard drie. It will ask if you want to repair. Press the R key and windows will reinstall your operating system, without destroying your software or data. After it is done the system will go to the windows startup screen. You will need your windows product key located on your machine or on the original software packaging.
    I hope this will fix your problem.
    Mar 17, 2009 | Dell Inspiron 6000 Notebook
    Hp zx7000 laptop hangs on startup hp logo
    Try starting it in safe mode. Instructions here:
    http://www.bleepingcomputer.com/tutorials/tutorial61.html
    If it boots in safe mode, use msconfig to disable all startup items, then selective enable things one at a time until you find the program or driver that might be causing it to hang.
    Instructions here: http://support.microsoft.com/kb/310560
    If it will not boot into safe mode, you will probably need to try a repair install of Windows. You may want to consult a professional for that, depending on your skill level.
    Jan 28, 2009 | IBM ThinkPad T41 Notebook
    IBM ThinkPad T41 2373 Notebook Logo
    245 people viewed this question
    Top IBM Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    Computer Links
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
