Question about Konica Minolta magicolor 2400 Laser Printer
OPC Drum Error
Printer gave me an error to replace opc drum. Bought a fuse to replace on the drum (suppose to reset it) and I still have an error. Has anyone had this problem and can it be reset (opc drum counter)?
Thanks in advance for any reply
  • Reeses08 Dec 03, 2008
    Thanks for the replies, I finally got it fixed. It was working great, but I messed with the yellow ink (roller had smudge) and now it tells me ink is out. It is new ink, so I know that is not correct.
  • 118 Answers
Replacing the fuse is only half the job. You also need to empty all the spent toner out of the drum as well. I actually drilled a 1/4 inch hole, poured out all the purple toner, and covered the hole with an old 5 1/4 floppy write protect tab. Any good piece of heat resistant tape should do. Then replace the fuse. Make sure that the contacts the fuse rests on are clean as well.
Posted on Oct 30, 2008
  • 3 Answers
I just replaced the fuse, I think I got it from radio shack, I didnt have to empty the toner, I just replaced fuse and it worked.
Posted on Dec 03, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
OPC-Life over error. How to fixit
If the print quality is still acceptable you may be able to perform a reset on the drum counter. If print quality is bad you will need a new drum. Reset instructions at this site.
Brother HL 2150N Drum Unit Reset Instructions
May 26, 2015 | Brother HL-2150N Laser Printer
Replace pc
Replace your Photoconductor(OPC Drum),before replacing must be reset the drum counter.
Jan 22, 2013 | Konica Minolta Minolta 7130 Laser Printer...
What is (SVC E9 Error)
Hi there
The error indicated on the 8008, ‘SVC E9’ indicates the printer is not detecting the OPC belt as rotating in the printer. The printer ‘looks’ for two black squires on the left side of the OPC Belt (as viewed from the front of the printer) if the printer does not ‘see’ black squires the printer indicates the SVC E9 error.
If the printer is displaying the SVC E9 error the most likely cause is something to do with the OPC Belt, normally removing the OPC belt from the printer then re-seating the belt would resolve the problem in most cases, as the OPC belt may not be locating correctly in the printer.
Unfortunately you have already removed the OPC Belt from the printer without resolving the problem, it may however be worth removing the OPC belt again and to look at the green reflective surface to see if there any damage or if the green surface is fairly central and is no skewed or bent in any way.
Depending on which position the OPC belt stops in you may see the black squares down the left side of the belt, if you can see these and they don’t look damaged or scratched the printer should detect the OPC belt ok, so the problem may lie with the sensor on the printer its self.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | TallyGenicom 8008 Laser Printer
Lines in paper. New toner, adjust darkness but still light. Needs service
yes, it need to be replaced the opc drum, opc drum cleaning blade and the developer, or just the opc drum and cleaning blade for the opc drum. Best turn out is to be done a regular PM service on the machine and to be replaced the opc drum and the opc drum cleaning blade.
Dec 22, 2009 | Savin 2545DP Black and White Copier
Tally t80063 service error 9
The SVC E9 error on the 8008 indicates a 'Belt Marker' error.
Basicaly the printer is not detecting the OPC belt rotating.
Check the OPC is not damaged, in particular check the left side of the OPC there should be a black squair that trips the light sensor which detects the OPC belt rotating. Check there is no damage here.
Locate the belt mamarker sensor, and clean it, this is on th left side of the pritner towards the top near the drum cleaner I think. It reflects of the left side of the OPC belt.
Check the OPC belt is turning, there could be a motor / drive problem.
Sep 16, 2009 | Tally T8006e Laser Printer
Error message svce 9 what does it mean ?
Jul 16, 2009 | TallyGenicom 8008 Laser Printer
OPC Belt needs replacing
Try pressing 1 and 7 at the same time
The LCD will show "OPC belt 1. Reset 2. Exit
Select 1 to reset the life counter.
This is supposed to be done when replacing the drum unit...but I've found that I can get 1.5 to 2 lifespans from a single unit.
Jan 31, 2009 | Brother MFC-9420CN All-In-One Laser...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Drum Cartridge Warning won't go away
Replace the fuse on the bottom of the drum cartridge.
Oct 03, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
829 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
