Question about Dryers
Frigidaire electric dryer, model FEQ332ES0
MY DOOR ON THE DRYER WAS LEFT OPEN BY ACCIDENT FOR ABOUT A WEEK. WHEN I CAME TO USE IT, THE LIGHT WAS NOT ON INSIDE, YET THE BULB IS GOOD, AND THE DRYER WILL NOT START. WHAT WOULD CAUSE THIS???
5 Suggested Answers
dinomb
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
TheMobilian
  • 8205 Answers
SOURCE: Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Posted on Feb 04, 2009
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 93 Answers
SOURCE: dryer bulb out, dryer will not turn on
no you dont need a bulb for the dryer to run check the plug or the breaker thanks from gilles
Posted on Mar 15, 2009
  • 572 Answers
SOURCE: Frigidaire dryer gallery series electric won't
check the thermal fuses in the back
Posted on Feb 12, 2010
I have a Frigidaire Dryer FEQ332ES0 that will not start unless I hold the pushbutton in inside the door and give the drum a stout spin. I will kick in and then run but door is open, not good
You have a shorted motor. The motor has an open start winding. If you press the door switch and then turn the dryer drum and if this gets it to start, that's the problem.
Nov 06, 2015 | Frigidaire Dryers
Need to know which color wire goes to which connector on the timer. frigidaire wiring diagrams
Hi garyab9ss, I appreciate your post!
It appears your inquiry is listed under Frigidaire Electric dryer and you need the wiring diagram. May I have the model number please? You can typically locate the serial tag (which lists your model number) on the upper front, as you open the door or on the right/left edge on the inside of the door. Also, please provide me the timer part number that you have in hand. With this information I can deliver the correct material to you. Thank you! - Z
Jul 28, 2014 | Frigidaire Electric Dryer
Hi, my FEQ332ES0 stopped starting up (after a day of no use), and it makes a faint buzz when I hit the start switch. The tumbler light works, and I OHM'd out the thermal limiter and it looks fine. Any...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 14, 2010 | Frigidaire FEQ332E Electric Dryer
Dryer runs when door shuts. Only stops when door is open
There is a safety switch in the door that shuts dryer off when door is open. If there is more to your problem let me know. From what you have stated there is no problem.
Jun 06, 2010 | Frigidaire FEQ1442ES Electric Dryer
High efficency dryer won't spin-Frigidaire
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
Mar 22, 2009 | Frigidaire FEQ332E Electric Dryer
Dryer bulb out, dryer will not turn on
Mar 15, 2009 | Frigidaire Dryers
Moisture in dryer
you have a clogged vent, somehow your vent has become clogged either with in the hose, or where it exits the house, the moisture being removed from the wet clothes is not leaving the unit. CHECK YOUR VENTING POTENTIAL FIRE HAZARD!!!!!
Oct 26, 2008 | Frigidaire FEQ332E Electric Dryer
Dryers Logo
114 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
