Question about Mitsubishi VS-60719 60" Rear Projection Television
60in mitsubishi the STK IC's that your talkin about just so I make sure that I'm certain what your talkin about its the black box with like 25-30 pins on the big aluminum sink? or is it something elses that i dont know about
  • fredcrabtree Aug 24, 2008
  • 2,326 Answers
Where do I send you the service manual?
Is a PDF file.
Posted on Aug 24, 2008
Convergence color is not converting
Replace convergence IC (location 8c01) which is a STK-393-110. You will need to order an after market market convergence IC (STK 393-110) I have had good luck with this IC. Next, check and replace all the 3.9 ohm 2 watt resistors, that are bad. You can check them with an ohm meter or visually inspect for burns or peels. Resolder the Convergence board, as by now there are many bad grounds (broken solder connections). Be sure to resolder the jumper jacks that connect the board to the next board too.(Under this board are solder traces that adhere to the jumper connections that will snap to the next board.) These would include jumper jacks PM, VU, and PF. Good luck and thanks for asking, show all hands of support!
Apr 10, 2011 | Mitsubishi WS-55807 TV
There is double text in red and green.
u have bad convergence ic , this parts is easy to located there 2 big black peaces the parts # start with stk , u have to do alot of soldering connection , or u can hire a tv tech and paid about $200
Nov 03, 2010 | Mitsubishi VS-50111 50" Rear Projection...
I am having convergence problems and need to know if there is really a difference with Sanyo and Sanken STK IC convergence chips?
Just the name, Sanyo quit making the STK series several years ago Sanken, Toshiba and Mitsubishi all have good versions of the STK series.
Aug 25, 2010 | Zenith R50W46 50" Rear Projection...
My mitsubishi TV ws-55859 does not turn on. The green timer light comes on and goes off after 3-4 seconds but tv does not turn on. What could be the problem? Help please......
Poor solder connection and Bad STK ICs 2 of them replace Both Big Black IC will have part number on them Call Mats for STK 1-800-628-1118 example
Nov 18, 2009 | Mitsubishi WS-55859 55" Rear Projection...
My screen looks like the tracking off. It wount stop flickering
Some electolytics on a small regulator IC are going bad. Take it to a shop.
Apr 30, 2009 | Mitsubishi VS-60707 60" Rear Projection...
Convergance- Red X will not move to make crosshairs white. Picture is doubled with red and blue. TV is a 55 in Mitsubishi VS55601.
This problem is related to the Convergence controller IC called STK.It must get malfuntioning replace the STK IC with the same numer IC. But one thing is importent that there must be two IC STK's and you have to change both of them.
Oct 11, 2008 | Televison & Video
No sound
Check connections in the back to make sure audio is being fed into unit, if it is replace audio ic stk-###. Its the only one not in a pair.
Sep 13, 2008 | Mitsubishi WS-48513 48" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Convergence IC
The convergence IC's are black in color with white lettering on them and will start with STK. These IC's will be standing up and be about 2" X3" in diameter. These IC's will also be mounted up against a large metal device called a heat sink. good Luck
Apr 08, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-60719 60" Rear Projection Television Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
