Question about Ezonics EZCam Webcam
Possible USB port problem, video feed is white or distorted
I have a possible USB port connection problem with my camera, need to know if this is due to the camera or the port... Video works after reinstalling drivers, but only for a moment, freezes and the video turns white.. computer recognizes camera. Please if any one can help me figure out why this is becoming a problem.. Let me know at peanutwoman83@yahoo.com thanks
Necesito driver de esta cam gracias de_takito@hotmail.com
Posted on Aug 23, 2008
How do I connect my K7 to a 1394 socket
Your Pentax K7 lacks firewire (1394) connectivity, so a connection to a fireware jack will not be possible without purchasing an inexpensive Firewire to USB adapter . From the manual:
Available Ports:
  • USB 2.0 hi-speed, AV out, HDMI out, DC in, cable switch, 3.5mm stereo microphone.
  • Video out: HD (1080i30, 720p30, 480p30), NTSC, PAL
  • Printer interfaces: n/a
The I/O (input /output) panel on a Pentax K7 camera.
You can connect a USB cable from the "PC/AV" on the camera to your computer's USB port with an appropriate cable to transfer image files for editing, etc. Additionally, you can send video directly to a TV with an appropriate cable via the camera's HDMI jack.
I hope this helps!
Oct 04, 2013 | Pentax K7 Digital Camera
My olympus sp-800uz is not installing the software to my computer and the usb connection will time out. I can not get any of my photos or videos off of it.
1. Did you try another USB port? It is possible that the USB port you are using is at fault. 2. To check if the camera and/or camera USB cable is correct, try to connect the SP-800 camera on another computer. Do not use a SD / SDHC memorycard in the camera at first, the software is loaded on the internal memory.
Apr 12, 2011 | Olympus SP800UZ Digital Camera
Dear Sir I have one p-4 computer and USB webcam i want to connect to 4 webcam in single PC. its posible to work 4 camera working at same time i not want to purchess any new hardware .if posible please help...
Yes, it is possible to connect multiple webcams to a single computer and have the computer detect and receive feed from all of them.
just not sure if it is possible to simultaneously receive feed from all of them.
All you need to buy is a USB hub, there are 4 ports and 8 ports USB hubs.
Feb 26, 2010 | Logitech QuickCam Express Web Camera
I plug my camera into my computer and my computer won't find it .
If the camera is not detected by the computer what you can try here is to try connecting the camera on a different USB port and check if it will be detected , but if still not detected if possible for you to try a different USB cable that will be better or if possible also try to connect the camera on a different computer so we can isolate the problem if its just the USB cable , the USB port or the camera itself that is bad...
Jul 11, 2009 | Kodak EasyShare M863 Digital Camera
Mass33@gmail.com
no not possible...u might be using ieee1394a to usb
but u cant use usb to connect to pc...u need firewire400 port with pc also....so buy another cable
u may reffer to
http://answers.yahoo.com/question/index?qid=20080827193702AA9sXJg
Sep 22, 2008 | Video Cameras
Connection
unless u have an USB port it is not possible to connect ur camera to pc, but if u have a tv tvner card in ur pc u can connect ur camera to pc..
Aug 03, 2008 | Quasar VM-L152 Camcorder
S-video port
Fist of all I like to inform in computer S-Video output of the camera usually does not fit to computer. Only if the computer has S-Video Input card it will be possible. However logic is simple. Digital Camera or Camcorders uses 1394 or USB connection to connect to the computer. You havent indicate what model of JVC you use, almost all JVC Digital Cameras come with USB connection option. All you need to put USB cable in between. If it asks driver, use the CD comes with the Camera or download from JVC's support website.
http://support.jvc.com/
Good Luck
Dec 30, 2007 | Microsoft Windows XP Professional With...
I want to capture movie from dv tape to compaq presario notebook
You are mentioning that you are trying to transfer video though USB port, that is not possible, you have to connect the to the pc through the DV port from the camera to the Firewire port of the PC, if your PC doesnt have a Fire wire port, install a IEEE1394 firewire card in one of your PCI slots.
Dec 01, 2007 | JVC GR-D270 Mini DV Digital Camcorder
Where is port to connect USB cable?
I'm sorry you're having trouble with this. I have put together a picture that shows where the mini-USB plug is supposed to be attached to the camera. I hope it helps. This picture actually shows plugging the AV cable into the receptical, but right behind it is the mini-USB port. This is where you connect the USB cable. It looks like you have to lift the flap on the corner to reveal the plugs.
Nov 24, 2007 | Canon PowerShot SD1000 Digital Camera
Panasonic NV GS 400 mainboard problem
What he probably means is that the IC that "Drives" the "Port' has been damaged or destroyed, a very common problem. Due to the manufacturing method, IE: Surface mount compnentry, there simply aint no "Simple Soldering problem" fix, at all... the actual IC, must be replaced... but this isn't actually possible..(well technicaly it is possible, but real hard to do) so hence the only other "Fix", a board replacement. Although ya DV outlet is kaput... If there is another output? say an A/V out? could you not use that as a work arround?
Aug 31, 2007 | Panasonic NV-GS400 Camcorder
Ezonics EZCam Webcam Logo
42 people viewed this question
Top Ezonics Computers & Internet Experts
micky dee
Larry Maranto
GFTALON
Are you an Ezonics Computer and Internet Expert? Answer questions, earn points and help others
