Question about NEC VT460 Multimedia Projector
Hooking up projector to my computer
When i hook up my projector to my computer nothing happens ...what should i do..?
  • official999 Aug 23, 2008
    Why wont my projector hook up to my computer/?
    Scholar:
  • 147 Answers
If it's a laptop, you might need to activate the vga output, using the blue "fn" button in combination with f4,f6, f7 or f8, depending on your manufacturer.
On an HP, you press FN+F4 once, to turn off the LCD, and use the projector. Press it again to run both at the same time, and press a third time to use just the LCD. The cycle repeats on each press.
Posted on Sep 17, 2008
  • David Friesen
    David Friesen Sep 17, 2008
    also, make sure your laptop's output resolution does not exceed the projector's resolution.
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old)...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
May 17, 2011 | Apple MacBook Pro Notebook
I'm trying to hook up a projector to my Acer laptop. i've tried function plus F5...nothing. Help
Make sure that your projector is set to the correct input. I have seen this happen many times, and that is likely the problem. Do not hesitate to comment if this does not solve your problem.
Feb 11, 2011 | Acer Aspire 3004WLCi Notebook
My toshiba satellite l355 won't show the video through an epson multimedia projector. What is wrong?
Occasionally this happens if you have had the computer hooked to a TV. I have had to disable the existing icon in Catalyst Control, and reboot. It should then find the projector, unless you have it set to manually find. There are several ways you can enable the projector, but they all boil down to the computer has to find the projector connection before anything else will happen. If it thinks there is still a tv hooked up, it will not work with the projector.
Aug 03, 2010 | Toshiba Computers & Internet
Projects upside down
go into the menu and reset the setting to factory default.
Dec 17, 2009 | Epson PowerLite® 83c LCD Projector
Why is the screen blue?
Check the connection of the cable from PC to projector.
Oct 12, 2009 | NEC Office Equipment & Supplies
Stuck in standby mode
The light bulb must be seated in perfectly, otherwise it won't see a connection and won't come on. take the bulb out, and make sure the connections don't have any dirt on it. Anything that can obstruct a connection. Give that a try.
Jan 09, 2009 | Sharp XR-10X Multimedia Projector
Colors showing red on screen
Hi Stella,
There is a button on the projector called "Auto Image"
Most people don't realize it's even there.
Press it while you are seeing this problem and most likely the projector will figure out the image issue and all will be well.
Note: this feature is nowhere in the menu(s)
Good Luck!
SagerTronics
Oct 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Presentation mode is off...
Hi there
You cannot hook up a PC & Projector with just a USB cable , you have to use a VGA cable for signal ( picture )
The USB cable is just to use the scroll up or down function from the standard remote controll when doing a presentation.
Apr 14, 2008 | Hitachi CP-X260W Multimedia Projector
Connecting a Optoma Projector to a Toshiba Laptop
I bought mine new... hooked it up and got the same response. I would have torn my hair out but I am bald! Checked everything. Great frustration. Finally, I thought to replace the cable with one I have on my monitor. Worked perfectly! A brand new cable and it was faulty! Contacted the company and they sent out a new one. Even sent a packet to ship my bad one back so they could find out what happened. No connection problems with the new cable.
Dec 18, 2007 | Optoma EP719 XGA DLP PROJECTOR 2000L...
NEC VT460 Multimedia Projector Logo
932 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
