Question about Samsung 226BW Monitor
Samsung 2232BW - blue line
Hi, there is a blue line showing in the middle of my screen (from top to bottom). If you choose a dark color as your background color, the blue line is very prominent but if you choose white for example, you will not see the blue line. As well, if you open a program, whatever that program is - the blue line is behind whatever program you have open or using. How do I get rid of this blue line. It just recently showed up. Thanks.
  • dougamy22 Oct 06, 2008
    I have the same line but mine is horizontal, about 4 inches down from the top
2 Suggested Answers
mdsaeed67
  • 849 Answers
SOURCE: Samsung Monitor 2232BW
consult a technician you could not do any thing for this fault
Posted on Nov 07, 2008
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 03, 2017 | Vizio VO320E LCD TV
Samsung HLN617W DLP 61" TV only show green color
BINGO! Light Engine, Maybe listed as- Assy Engine Go to website Encompass Parts Distr their you will find what you need or Call 1-800-638-3328 ,or Try UED 1-800-648-6657
Dec 01, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
I have a blue line in my monitor
line driver element defective. no repair possible, to my knowledge. replace LCD or ignore line.
Mar 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Aug 23, 2008 | Samsung 226BW Monitor
Curved blue lines on screen.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
Aug 06, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
140 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
