Hello, i cannot close my lap top cover, seams that the frame covering the scream is broken at the left side corner, is it expensive to have it repair,i found little black pieces on my table...the problem occured today.i had ny computer for 3 years now, how do i get this fixed. I live in laval quebec.When i try to close my computer, the whole side buclles . it is a wonderful computermever had problems with it before. Please e-mail address is you in advance, yours truly, monique
  • 3,051 Answers
I would contact the manufacture of the computer and inform then about this and check to see what price it would cost to repair it
Posted on Aug 23, 2008
The screen states "close cover E" It is closed but the screen keeps saying " close cover E" ?
The Exit 2 interlock switch is either broken or off it's base or defective. If you open up the top door on left side of print, there is a push button switch that mounts on the back side. If you're standing on the left side of printer it's located on the top left. Make sure it's mounted properly and try to push the button with your finger and see if error goes away, if not replace switch, part number 110E11580.
Sep 23, 2015 | Xerox WorkCentre Pro 123/128 Printer
How do I take the bleach dispenser out of my top load washing machine.LG WT5001CW
Hello. The bleach dispenser cover(the part you see) un-snaps and lifts out revealing the dispenser assembly beneath. The part number for the cover is MBL62061401 and the dispenser assembly is ACZ72910401. Why are you taking it out? If there is some leakage down the front of the machine, make sure the washer is VERY level as the basket/tub ring will lean towards the side that is lower. Check the suspension rods for wear by placing your hands on the right and left side of the tub ring(the white circular cover over the spin basket)and shove smartly downward and let go. The suspension rods should grab going down and pull coming up--no "hobby horse" wiggling/bouncy movement at all. They act just like shocks on a car--if you push down, the car will come up and immediately settle. The suspension rod part number is 4902FA1665W and you will need to change all four if any corner is worn. **To access the rods and dispenser assembly, you must use a 2 inch putty knife, insert is approx 3-4 inches(use a flashlight to help you see) from the right and left side *front*. There are 2 steel clips that hold the top cover tightly to the washer frame. You have to push them in while pulling the top cover towards you and up. Place your hand inside the lid and grab the top cover tightly at the front right and left sides--the clips can be really tight and difficult to get released so be patient. The top cover will hinge up from the back. Be careful--some models have screws at the *back* corners of the top cover that have to be removed. I hope I helped you!
Aug 28, 2015 | LG WT5001CW Washer
How to remove dvd drive on aspire 5720
A) Remove the AC adapter (Charger) and Battery
B) Laptop closed turn it over, lay it down on a soft cloth on a table, Battery Bay Compartment AWAY from you.
C) The Thermal Cover is the largest cover on the bottom of the laptop. Goes from the right side to the middle, and very close to the Top and Bottom.
There are four Philips head screws to remove in the cover, before the cover can be removed.
1) Under the middle of the Battery Bay Compartment, and at the Top/Left corner of that rectangular vertical vent, in the Thermal Cover.
2) At the Bottom/Right corner of that vertical vent, in the Thermal Cover.
3) In-between the two horizontal vents, located at the Bottom of the Thermal Cover.
4) Straight above the screw removed in 3), is the last screw to remove. There is a round shaped vent, inside a square at the top right of the Thermal Cover. The screw to be removed is at this vent's Bottom/Left corner.
Once all the screws are removed, ease the Thermal Cover up from it's left side, (Middle of laptop), at an angle, then remove.
D) In the opening with the Thermal Cover removed, there is one Philips head screw to remove, then the ODD can be removed.
(Optical Disk Drive. The DVD drive)
This screw is located..............ack, ack,.......fzzzt.......ffffzzzt,......
Jun 02, 2012 | Acer Aspire 5720 Notebook
How to remove left and side casing from kyocera fs-c5025n please
FS-C5025N left cover removal.
1. Open the rear cover.
2. Open the top cover.
3. Remove the opening and closing axis from the main unit frame and then remove the top cover. It pry's out at the hinges.
4. Open the left side cover and then remove the one screw.
5. Remove the waste toner box. To remove waste toner box, press the lock lever in.
6. Remove the paper feed unit .
Feb 18, 2011 | Kyocera FS-5025N Laser Printer
How do i unlock a maytag neptune tl?
Disconnect the machine from power source then insert a plastic putty knife or similar tool in line with the lid seam and push in to release catches on the left and right side. The top cover can then be hinged up.
Once the top cover is raised, remove each of the 1/4" hex-head screw attaching each lid lock to the top cover.
Release the lid locks from the lid then reinstall them back into the top cover. Take the opportunity to visually check the lid locks and the harnesses for any obvious sign of degradation such corrosion and broken wires.
Sep 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Dear Sir(s) I have an OKI data OL400e the problem is "Message --Cover open" even i close it well Please advice Thanks
had the same problem. It is easily fixed.
On my printer a OKI C5750 is had to main covers, at the front (which you have to open to fix a paper jam) and a big cover on top (which you need to open to replace toners).
On the left is a piece of plastic which (when closed) presses on a switch.
When you open both covers, and close the top one, you can see it on the left when it comes down.
You can easily remove the error (only for a brief moment) by prushing the shining metal switch to the back.
But the problem is that one of the rollers is in a wrong position.
So just take a flat screwdriver and press on the bottom roller, and it will click and the problem will be gone when you close the covers.
Feb 11, 2010 | OKI OL 400e Led Printer
After my old fuser assembly wrapped and fused a sheet of paper around the rollers,I installed a new fuser. But now I get a continuing error message, "Jam in Exit Area" even though the paper path is clear,...
This error usually happens on Laser printers after removing a jam and the sensor is not correctly placed in the right location. "exit area" refers to the switch where the page exist the printer, you can find a black piece of plastic that moves, that is the "sensor". When it moves, blocks the infrared light from the photodiode. That is the source of the problem.
Perhaps the plastic part is not correctly placed so doesn't detect the paper exiting the printer OR some foreign material is obstructing the photodiode (perhaps toner? dust?).
Disassemble is required to perform a visual inspection. If everything looks fine, look for broken wires, faulty connectors (from that area).
If you don't have experience about disassembling the printer and need more assistance, please let us know.
I hope this info helps. Good luck!
Jan 10, 2010 | Samsung CLP-510 Laser Printer
The error message says Doc. Cover open but the cover is closed
You will probably have a broken hinge at the back left hand side of the Doc. cover.
This means that the cover won't close properly at the back corner, and the cover sensing switch won't actuate.
Dec 08, 2009 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC 7820N error message "back cover open" but cover is closed. machine is now not functional as error message can't be removed
If you open the back cover (depress the release button on the top right) If you lift it up look for two black anchors that grab the base when you close the lid. I have one that has a broken tab on the left side, which happens to be the same side as the cover closed switch. If the top is not closed all the way the rollers do not line up and the cover switch is not depressed to let normal operation. Also, if the switch arm is busted (case colored plastic push pin protruding from the cover) it will not make contact with the switch when closed. Try closing the cover and push down on left side of the fax. Does the error go away? If not, the actuator arm or the switch are bad.
Apr 06, 2008 | Office Equipment & Supplies
Door Latch
Larry, I believe you have to remove the inside door frame cover, starting at the top and working your way down. The cover should snap out and away from the door. Next would be the gasket bracket clips. With a flat tip screw driver insert into the seam between the gasket bracket and the door frame and pry out until the clips snap out. Then proceed to remove the gasket from the channel. Catriver.
Jun 13, 2007 | LG LRFD25850 French Door Refrigerator
Computers & Internet Logo
David Payne
David Payne
