Question about Saeco Incanto Classic Espresso Machine
Fill Water tank - Ventilate
Thank you for helping me with the Algae problem. I took care of that, but in the process, I started the machine without the water tank. The machine ran out of water, and displayed "ventilate." I added water to the tank (with a new filter on it), and the machine now says "fill water tank," despite the tank being full. I turned it off, and unplugged it, but nothing works.
Thank you again,
Mike
  • 1 more comment
  • garage240 Oct 03, 2008
    Have the same 'fill water tank' mesage displayed ,replace magnet and checked switch opperation with multimeter but still says fill water tank.
    Hope you can help
  • luisa ward Aug 09, 2013
    HI, We had the fill watertank error and faulty magnet that did not float up. We fixed it by removing the rubber top and then removing the "floating" magnet. It was waterlogged and wepried open the top, took the disintegrated Styrofoam out (this is what makes it float), dried the magnet and inside and then cut out a new piece of styrofoam and glued the top back with crazy glue. Put it back in place and popped the rubber top back in - It worked :) Had renewed bouyancy. I can't imagine why Saeco does not have a better buoyancy material and a better seal.
  • Anonymous Mar 31, 2014
    When I fill the water tank, the machine still tells me to fill it. So I have to use a magnet.
    New Friend:
HI,
Posted on Aug 09, 2013
  • 515 Answers
Hi Mike,
Make sure the magnet flow up, if it flow up and you still get fill water tank then you have to replace the magnet.
If you get ventilate all time, try to remove the filter and try again.
/Mirran
Posted on Aug 23, 2008
SOURCE:
Remove algae from GV7070 water tank
Chlorine/bleach - read carefull the instruktion on the back og the bottle. DO NOT USE IT without thinning it with water in the correct dosis! Let it rest til everything is dead. Dont get it in the machine it will be damaged. Do not boil it in the machine! only for use in the watertank. Clean carefully.
May 21, 2014 | Tefal GV7070 Iron
Ventilate - how does onw fix this?? Run through liters of water (hot water) but it does not go away!
fill up the water tank start the machine open water valve run it for a minute close the valve ventilate should be off
Feb 27, 2011 | Saeco Royal Cappuccino Espresso Machine
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
Cannot solve "Ventilate" problem - weater circuit is broken
Turn the knob on after you press the hot water button, run the cycle until the message is gone takes a few seconds or about 2 ounces of hot water.
May 02, 2010 | Gaggia Titanium Espresso Machine
My Gaggia Titanium machine says ventilate
Run about an ounce of hot water from the wand.
Nov 10, 2009 | Gaggia Titanium Espresso Machine
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Machine says ventilate
When it says to ventilate, it is asking you to prime the pump. Put a cup under the panarello wand ( the steamer/frother) to catch the discharged water and press the hot water button (upper left button on my machine). Wait until air stops coming out with the water, usually 3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 11, 2009 | Saeco Royal Digital Plus Coffee...
Says "Fill water tank" and the tank is full
did you open the side valve to ventilate the air in the system in our water tank do you have a little magnet its in the water tank maybe it stuck downshake the water tank to move the magnet up pierre
Jan 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
Algae in water tank?
Try to clean it with soap, if you are careful you can bend in the edge and take it off.
Use some glue on it when you put it back.
/Mirran
Aug 22, 2008 | Saeco Incanto Classic Espresso Machine
Fill Water Tank
When we got ours, i took the back off and taped the magnet to the receiver. this ensures that the message vever appears, it is a very poor set up anyway for waht is an excellent machine. We are careful to ensure that we do not run out of water and this has only happened twice in 4 years - ventilate and your away again.
Jul 08, 2007 | Gaggia Titanium Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
936 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
