Question about Philips Magnavox DVD/VCR Dual Player
Problem with my dvd/vcr
My dvd/vcr just stopped workin and won't turn on and the fuse is still good ,if u can help me out to get it workin again it would help
  • Anonymous Aug 24, 2008
    the dvd/vcr player will not turn on when power button is pushed, it has power to the machine any help?
  • detrowr Aug 28, 2008
    I have 2 of these MWD2205 players and neither one will turn on. Is there a cammon component failure that causes this? The fuses are good and I can find about 18 volts DC in part of the power supply from the top of the board.
  • 8,596 Answers
Detro and guest - that model has a feature that won't allow it to be turned on if there is no video signal present - peruse the www.philips.com/support website for more info
Posted on Sep 05, 2008
After I turned the player off, and afterwards on again, nothing happened. How can I turn it on again? Is it possible a fuse broke down? Where can I find it in the apparatus?
I Have the same DVD /VCR but the cove will need to be taken off that there is a fuse in it ,on right side in the back on the circuit board . be sure it's unplugged .
Sep 11, 2013 | Samsung SV-DVD3E DVD Player/VCR
What make the tail lights and turn signals and gauage to stop workin
In most cases, if all those lights have stopped working at the same time, you have blown the "lights" fuse.
Replace the fuse, and check again. It should fix you right up replacing the fuse.
Jun 03, 2011 | 2007 Suzuki GSX-R 750
The vcr stopped working, tape goes in but won 't work. the dvd stills works.
most likely a mechanical issue , look inside for anything laying inside the VCR section.
a piece of a label or a toy etc. if all looks well it could be a bad sensor , bad (dirty)mode switch
or sinply a jammed gear or arm.
a good way to check the VCR section is to turn the loading motor and see that it moves correctly
hope this helps
Dec 17, 2010 | Emerson EWR20V4 DVD Recorder/VCR
GO Video VR 3845 DVD/VCR combo will not turn on.
Yes,if u want to.Unplug,replug the unit back after about an hour or so.The unit should reset it self out of protection mode and work again,if nothing in the circuit boards are burn.
Jun 15, 2010 | GoVideo Go Video DVD/VCR Combo
Power windows will not go up or down
i can understand you,LOOK,this is simple,take your time,LISTENTO ME,OPEN THE DRIVER SIDE DOOR,AND LOOK AT,THE,BLACK RUBBER LOOM COVER,PULL IT IT BACK AND CHECK FOR BROKEN WIRES,NONE THERE??,THEN,DIAG,THE SWITCH,HOW?,GROUND UP,AND THE WINDOWS SHOULD GO DOWN!!!!!!!!!
Apr 04, 2010 | 1990 Buick Century
Daewoo VCR/DVD combo not turning on
check you power button it might be bad
Aug 24, 2008 | Funai Emerson DVD/VCR EWD2004
Magnavox DVD/VCR player stuck in progressive scan mode
Right, mine was stuck for a couple of weeks and i tried lots of different things. What worked for me was plugging it out and in again. Press the power switch and then just before the tv switches from normal mode to dvd recorder press the eject button. However, I pressed it a few time so not exactly sure which one worked.
The burned DVD is now in a thousand pieces at the bottom of my bin!
Good Luck!
Oct 20, 2007 | Emerson EWD2202 DVD Player/VCR
OWNERS MANUAL
from the manual:
turn on tv & set to video input mode. REMOVE erase protection tab from tape. Load tape & DVD. THEN ON YOUR REMOTE:
1. press DVD (DVD indicator lights up).
2. Press REC MODE/SPEED & choose your speed.
3. Press VCR (VCR indicator lights up)
4. press DUBBING
5. select YES
6. to stop dubbing, press STOP
good luck!
Oct 13, 2007 | Toshiba D-VR4 DVD Recorder/VCR
I can not turn off the proggressive scan!
Try this to disabel the progress scan mode: Pointing the remote at the player, press the STOP key to stop any disc that is playing. Next, press the STOP key again and hold it for five seconds before releasing it. This should turn the Progressive Scan off.
Oct 05, 2006 | Zenith XBV442 DVD Player/VCR
Philips Magnavox DVD/VCR Dual Player Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
