Question about RCA F36648 36" TV
No sound We just bought this used TV F36648 we get the image but no sound. Apparently the previous owners had outside speakers connected to the TV but I do not have any. What can I do?
    Problem Solver:
  • 7 Answers
Go into AUDIO settings in the MENU and make sure the settings for EXTERNAL SPEAKERS are turned OFF and INTENAL SPEAKERS are turned ON. Hope that helps: )
Posted on Nov 23, 2008
I have a 1999 Bounder 36s motor home that I just bought used. The previous owner apparently let it freeze up and broke the water lines. Where can I get a plumbing diagram?
manufacturer they will send you a PDF file but usually toilet valve kitchen faucet bathroom faucet shower head and outside shower usually break also the water pump you can put a fitting with 40 psi of air and listen for leaks
May 06, 2016 | RVs
Power to the radio but no sound coming out of the speakers previous owner said speakers work how do I find out
Ok, so you bought a used radio. Did you test it when previous owner gave it to you or you bought it through mail?
If you received with a not declared failure, you should it send back and claim your money.
Else, sorry, you should send it to repair
May 11, 2015 | Cars & Trucks
Hi got a RCA 36 model F36648 get sound but no picture can bring up menu, do i need to hook up a dvd player or vcr to it
You probably have the internal speakers turned off. Here's a link to the PDF file of your TV Manual:
http://download.rca.com/FilesForRCAcom/Manuals/15491880.pdf
Page 46 of the manual describes how to switch the audio (TV's speakers) on and off.
Mar 05, 2011 | RCA F36648 36" TV
I have a 42 inch Insignia plasma tv. I only hook
If you have the audio cables hook up correctly to where the video cable from DVD is connected to, it should be RED and WHITE wires for audio. Then go to on screen audio setup menu to see if the speakers is turn off in the menu. Also try hooking up the powered PC speakers to the AUDIO LINE out RCA jacks to see if you get the sound OK there.
Nov 03, 2009 | Insignia 15 in. Flat Panel LCD HDTV
No sound
More than likely you need to go into your menu settings. Check to ensure that your TV speakers are enabled. The previous owners may had it hooked to theater system
Oct 20, 2009 | Toshiba TP50G60 50" Rear Projection...
Mobile 7-inch tv monitor with dvd player has no
couple different scenarios here...first, the previous owner may have had the dpeakers amplified and removed the amplifier before selling the car, or he may have even removed the speakers themselves. ive seen this done alot with aftermarket equipment. check behind the stereo to be sure that the speaker wires are connected to the cars wiring. also peek in the door panels to make sure the previous owner left you with some speakers. after your sure theyre all connected properly check for sound. if nothing, then you have a problem with the unit.
Sep 02, 2009 | Car Audio & Video
Laptop to TV connection but no audio
what kinda connection did you made?? what kinda cord did you use....anyway...it usually works that way..you can get image on TV ..by setting the image card driver ...but the sound bust be connected separately ...if your TV has a input plug for sound...just take a proper cable ...and get signal from the green out of the computer and plug it into the input of the tv ...this way you will have sound comming from the TV speakers and access on the volume with its remote control ...but no matter what kinda plug u used for the connection with the tv ...you will not get eny thing more than image..
so...if your TV doesnt support sound plug in just attach some speachers ...
Jun 14, 2009 | Acer Computers & Internet
Rca f36648 & rca HOME THEATER
Have you tried just hoooking up the DVD player by itself? Is the DVD player output setting correct? Also, make sure the "video input" is set for the correct channel that you are viewing (i.e. Channel 3).
Jul 31, 2008 | RCA F36648 36" TV
RCA-f36648
How are you connecting up your tv? also getting new IF connector should not cost more then 100.00 at the most and thats to much .also what are you using for tuner source?you have to connect to vcr,satellite or cable box using externel jacks,use back av jacks yellow video- red&white audio,then you will be using channel 3 or 4 on tv to change channels thru your vcr,satellite,or cable box which ever one you are using for tuner.If you have it connected right your set should work.let me know if you need any more help with this.ThankYou for using FixYa and Have a Nice Day.
Feb 05, 2008 | RCA F36648 36" TV
RCA F36648 36" TV Logo
75 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
