SOURCE: Lowrance iFinder H2Oc analog speedometer...
I found that it works better to push exit three times from the map view.
SOURCE: How large of an SD card will a Lowrance IFinder
iFinder is the king of GPS devices with respect to memory. Though 1 gb looks a little bit too much for it in the time being and may well hang the phone .
You can purchase MMC cards with up to 128MB or SD cards with up to 64MB of memory
Hope this helps
SOURCE: purchased the ifinder H2O two
HI,
To fix this up you will have to do a reset.
CLICK HERE to download the manual and refer the troubleshooting steps.
Goodluck,
Please don't forget to rate the solution.
SOURCE: why wouldn't my ifinder h2o c gps not pick up any satalite signal
The most common reasons are thus
1) You do not have the right PORT and BAUD set
Consult the manual for the software.
2) You are noit in a location where the sky is visible to the unit)
move outside and away from buildings or electrical items
3) Your battery power is too low to get a fix
4) nThe SIIRF chip is damaged
Please rate my help++++Thanks for using FIXYA
SOURCE: lowrance h2o color unit will not track satelittes
My H2O I'm having problems pulling up the lake I am on.
