Tip & How-To about Computers & Internet
The primary purpose of bar codes is to encode the unique
characteristics of numbers and letters can be in a format that machines can
easily read. However, bar codes are read by people often also for this reason,
the codes generally include both parties readable and legible. The most popular
bar codes meet a standard called "Code 39". The latest version of the
code with 39 additional characters called "Extended Code 39." Among
other characters, Extended Code 39 allows users to include carriage returns
(CR) in bar codes.
1. Setting the bar code scanner to read "Extended Code
39," Code 39 is not as common support CR. The details depend on the
specific bar code scanning software is used, but you will usually find this
option under "Tools" then "Options."
2. Configure the software to generate bar code to the
"Extended Code 39" is also used. The details depend on the specific
software to generate barcode is used, but you will usually find this option
3. Type "M $" (without the quotes) at the point
where you want the CR model is within the barcode. M $ gives a CR Extended Code
39.
