Question about SanDisk Sansa m240 MP3 Player
Mp3 im having the same problem my mp3 wont come off the sansa screen how do i fix it
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 10, 2008
SOURCE:
My screen is frozen and wont play my music how do I fix this?
I have a 1966 ford fairlane and im changing to summits dis box with disribitor will this affect the voltage regulator or will this replacit
Jan 16, 2010 | SanDisk Sansa c140 MP3 Player
My computer wont recognize my mp3
I know this is only part of the solution:
- turn off your sansa clip
- put the slide button on hold
- press the centered button while connecting the sansa clip to your pc
the sansa clip will now be visible as a removable disk under 'my computer' :-)
I don't yet know how to proceed from here on
Sep 20, 2008 | SanDisk Sansa Clip MP3 Player
Sansa E280 Video Transfer Problem
im not sure how to fix this problem, but anythingbutipod.com has a great forum that will help you fix your problem.
Jul 07, 2008 | SanDisk Sansa E280 MP3 Player
Sansa wont work
Download the Sansa firmware upgrader and install it first. Then, hold in the volume + button on your Sansa player and connect the Sansa to your computer (while it is in the OFF position). The computer will recognize the player after you continue holding the volume + button for 5-50 seconds. Restart your computer. You will lose all files stored on the Sansa, but it will work again.
Mar 29, 2008 | SanDisk Sansa E280 MP3 Player
Screen Cracked
Unfortunately you wont be able to fix the crack screen..you will have to get a new MP3 player...
Hope that help you
Please rate accordingly..
Jan 29, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e260 screen not working
does the dial stay on and won't shut off?
Jan 27, 2008 | SanDisk Sansa e260 MP3 Player
Help my sansa is broken
i have the same problem....i am currently trying to get mine fixed. Sandisk told me to take a picture of the broken mp3 player and send it to [email protected], i have sent it to them 8 times within the past 2 months and they still said they have not recieved it. let me know if you find anything out...
Jun 22, 2007 | SanDisk Sansa e250 MP3 Player
Reset button
This is a well know fault with the m240. The easiest fix is to take it back to the store you bought it from and get a replacement :)
Jun 12, 2007 | SanDisk Sansa m240 MP3 Player
Sansa m240
Hi. I'm having the same problem with my m250 and am concerned, since I've only had it for a month. Nothing I do, including removing the battery, hooking it up to my computer again, or holding the power button down for a long period of time works.
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
