Question about Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens
Excessive hunting with Olympus E510
I've tried using my recently acquired used bigma with my E510 as well as my brother's and it is extremely difficult to focus on moving objects (e.g. flying birds) even in bright light. By comparison, my brother's Nikon mount bigma locks focus easily with his D40X under the same circumstances.
Rgds,
Dexter
3 Suggested Answers
cammedic
  • 667 Answers
SOURCE: trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
Posted on Dec 28, 2007
SOURCE: Sigma 18 -200 lens with D40x
This lens is NOT compatible as the body doesn't have a motor . £200 wasted
Posted on Jun 09, 2008
I have an olympus e510.when i take pics inside or in darker areas the flash goes off alot.how can i fix this
That's because you are using auto focus. That system needs light to actually focus. When it's lacking enough light it uses the build in flash to create enough contrast to focus the objective.
Solutions :
- change to manual focus (mf)
- mount a external flash: then a different method to focus is used
- use a small pocket lamp (the light it produces fades away in the flash)
Sep 16, 2011 | Olympus Evolt E510 Digital Camera
Hi, I've recently acquired an "Apache",
Mark, my best recommendation is to contact Kaba Ilco Tech Support with your particular problem. They are located on the East coast.
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Good luck--and please provide feedback if this helps!
Aug 31, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
How to use olympus e520 in less light
The first answer is from some one who obviously is not familiar with Olympus (and many other brands of DSLRs) or he would know that many lenses do not have manual focus scales to use. Olympus Standard Grade lenses do not include a focusing distance scale.
The more important issues for you are determining -
1) Are you trying to use "Live View" to focus?
If so you are using a less sensitive auto focus mode. One of the benefits of using a DSLR is that it can use more sensitive auto-focus systems than Point
Sep 05, 2010 | Olympus Evolt E510 Digital Camera
Dell Dimension E510 - Keyboard compatibility
Hi, to find out if the “Keyboard is compatible with your system?” You can do the following: Shutdown the Computer, connect the Keyboard to your computer. Turn on the computer. If, the “Keyboard have a Power Button?”(Turn on) the keyboard. Go to, Control Panel; click on Device Manager. Click to open Keyboards, in the (Keyboard Properties) Click on Driver (Box), next click to Update Drivers! Click OK. Restart the computer. Check keyboards’ functionality. Thanks paul7of9
Jan 14, 2010 | Dell Dimension™ E510 PC Desktop
Rm-1 Olympus remote. I have 2 of them and can not get them to work with my Olympus E510. New Batteries, tried to set frequency. No luck. Any advise?
Starting on page 45 of the user manual explains how to use your RM-1 remote control. You have to set up the camera in remote control mode in order to fire the RM-1.
May 10, 2009 | Olympus RM-1 Remote Control
Can not capture image
reset the camera back to factory default using the menu. Put camera is p mode, menu, custom reset, custom reset, ok, yes,ok
Apr 06, 2009 | Olympus Evolt E510 Digital Camera
VOLUME ISSUES
does not record sound on this camera
Mar 17, 2009 | Olympus Evolt E510 Digital Camera
Olympus E510, Flash Flicker
If you are in a low lit area with the camera dial set to Auto the flash will do a strobing type of flash trying to help allow more light into the scene. This is called the AF illuminator function. To just go ahead and take the image, put the camera dial to P (program Auto) go to Menu - go to Wrench 1 tab - then right arrow over and then down arrow to AF Illum - right arrow and turn this function from On to Off and then take the image in the P mode setting. No flash flicker should occur.
Nov 03, 2008 | Olympus EVOLT E-510 Body Only Digital...
I have an E410 DSLR and am trying to use a Sandisk Extreme IV CF card of 4GB. I get message stating card full until I try to format it and then get a card error. Can you help ?
Currently Olympus has successfully tested Sandisk Extreme 3 up to 8gb without any card error messages. It sounds as if it is a card compatibility issue. Try to exchange to an Extreme 3 and you should be able to use that without any issues.
Aug 29, 2008 | Olympus Cameras
Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens Logo
83 people viewed this question
Top Sigma Cameras Experts
Steve
Doberman
Are you a Sigma Camera Expert? Answer questions, earn points and help others
