Question about Fuji DX-7 Digital Camera
I am still getting communication errors. Is my camera defective? (Fuji DS, DX and MX digital cameras only)
    Master:
  • 425 Answers
As long as the camera is taking pictures and playing back the pictures on its LCD, most of time the camera is OK. Serial communication port of Digital Camera is rarely damaged. If you are using Windows '95, there is a way of verifying the serial communication port. Following are the instructions: a. Open Control Panel from the Start/Settings menu. Double-click Accessibility options, then go to Mouse and activate mouse keys. This feature enables you to use the numeric keypad to move the mouse pointer. (For details please refer to the Help index of Windows 95) b. Turn off the PC and the Digital camera. Remove the Serial mouse from 9 pin connector, then connect Data transfer cable to the 9 pin connector and the other end of cable connect to the Digital camera. Turn ON the PC and the Digital camera. From this point the numeric keypad can be used for Mouse functions. Start the FUJI data transfer software, select COM 1 from the Communication ports within the "Communications Settings" item of the "Camera" Menu. c. Go to "Get images from Camera" of the "Camera" Menu. If you get a blank thumbnail, your Digital camera is communicating to the PC. To receive thumbnails of all pictures go to "Edit", go to "Select All", then click the 3rd Icon from the left. Progressive indicator shows "Receiving thumbnails". In this case the Camera is OK, and the problem is other than with the Digital camera.
Posted on Aug 30, 2005
SOURCE:
Fuji finepix s5700 digital camera
Hey Sharon.Dose the error appear when you directly connect the USB cable to the pc and try to download the photos on the camera?
Nov 21, 2011 | Fuji FinePix S5700 Digital Camera
Fuji finepix communication error mac
hey Sharon the only way i would imaging to bypass that problem is by getting yourself a multi memory card reader where you take out the memory card and insert it into the card reader and copy all your photos to the PC and then inserting it back into the camera. According some people its not good to use your camera as a card reader. Although it has that function.Hope this helps.
I have lost my instruction book and need it replaced. what do I do when it shows ''read error''?
There's a communication problem between the camera and the card. Try gently wiping the golden contact plate on the memory card with a dry cloth.
If that doesn't help, the card is most likely defective.
Feb 07, 2010 | Fuji FinePix S3000 Digital Camera
Communication Error when uploading photos
You may have switched USB mode to Pictbridge by mistake.
Press Menu/OK, select Setup, choose USB mode (on 3rd page) switch from Pictbridge to DSC, press OK.
Oct 05, 2009 | Fuji FinePix S1000FD Digital Camera
Frame error
Backup the photos already on the card, then format it in the camera
Jul 10, 2017 | Fuji MX-2900 Zoom Digital Camera
Fuji dx10
Search Manuals: http://www.devicemanuals.com/guide/Digital%20Cameras/Fujifilm/Fujifilm-DX-10-Software-User%27s-Guide-TmpJNU9UQT.html
Fujifilm DX-10 Software User's Guide @ Yahoo
Fujifilm DX-10 Software User's manual @ MSN
Fujifilm DX-10 Software User's instruction @ AlltheWeb
Fujifilm DX-10 Software User's handbook @ LookSmart
Fujifilm DX-10 Software User's repair manual @ HotBot
Fujifilm DX-10 Software User's service manual @ AskJeeves
Dec 28, 2007 | Fuji DX-10 Digital Camera
My OS is Windows 3.11 and I am getting communication errors. (Fuji DS, DX and MX digital cameras only)
There is a problem due to comm.drv which is located in system folder of Win.3.11. If the comm.drv is dated Nov.1. 1993 and is 5,968 bytes, please check the property of the comm.drv within your PC. Although the problem is due to the comm.drv, FUJI has prepared a new sdt-7 for Win.311. Please call Customer service at to obtain the sdt-7 or go to the ftp site and download sdt7w31v20.exe. It is important that your PC has Win 32s loaded before install your new sdt-7.
Aug 30, 2005 | Fuji DX-7 Digital Camera
I am getting communication errors. Error Message appears in the display "Your camera or PC is not ready." (Fuji DS, DX and MX digital cameras only)
Most of the time the problem is due to the serial port setting of your PC. Please follow instructions below. Cause Camera is not communicating to your PC. Remedy Please check the following. 1. Cable connection. 2. Camera is ON and in PC mode. 3. Camera's batteries are not exhausted. 4. Go to Communication setting from "Camera" and make sure proper COM port is selected. 5. If your PC has external input device, disable its driver such as "Hot Sync" or similar drivers. 6. If your PC supports PS2 mouse, please use it instead of serial mouse. Then one serial port is available for the Digital camera. 7. Check in the BIOS Setup Screen to make sure the serial port of the PC is not disabled. Also, if your personal computer is equipped with an internal modem or infrared port, it may cause conflicts with port assignments internally that will not allow communication with your camera and PC. In such case, it is necessary to change the COM port setting for serial port. For details, see the User's Manual for your personal computer, or ask at the store where you purchased your personal computer
Data Transfer Software (sd-t7) does not start. (Fuji models: DS-7, DX-5, DX-7, DX-9, DS-220, DS- 300 and DS-330)
Make sure you have more than 8 MB of memory allocated to sd-t7. This does not mean you only need 8 MB in your Mac. Use "Get info." Command to assign at least 8 MB for sd- t7.
Is my MX/DX/DS series digital camera compatible with Windows XP?
No, these cameras are not compatible with Windows XP. We recommend using a memory card reader such as the DPC-R1 to read directly from your camera's SmartMedia card.
Fuji DX-7 Digital Camera Logo
87 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
