Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Akai HDTV 1080i won't turn on
I have an Akai HD projection TV that won't turn on when pressing the power. You can hear that it is turning on, but the screen remains black as if it is off. My son told me earlier that when watching tv and turning if off later, that the screen went from red, to pink, to blue, then green and turned off. Need your assistance in figuring out what the problem is.
  • caddo0 Sep 03, 2008
    checked cords, doesn't come on, went off abruptly
  • Anonymous Jan 05, 2009
    My Akai 1080i will not turn on but it appears the power is on any ideas?
premtech
  • 934 Answers
SOURCE: akai 1080i hdtv 54in
Sounds like a regulator problem, possibly the low voltage side of the regulator. Could be the the regulator itself has shorted which in this unit is a STRF6628. If you're trying to attempt repairs yourself take a look at C834 100uf/25v next to the regulator and see if it's possibly open. If so replace it and see if the unit will power-up and let me know..
Bill
Posted on Nov 21, 2007
melnavz
  • 1226 Answers
SOURCE: Akai Rear projection 42" hdtv
Hello!
Please try to unplug the power outlet to reset the setting automatically. and change the image setting of the TV. However, if this donot work. the projection of the TV maybe cause damage. On that case the error maybe in either in the horizontal or vertical setting of the tv. In this case you need a service tech to check the circuit inside. this needs a series of testing each parts of the TV. If the TV is less than a year then you can claim a warranty howver if this more than one year, service tech im sure it level on very reasonable cost same very cheap labor cost.
may this help, melnavz
Posted on Mar 05, 2008
  • 1779 Answers
SOURCE: I have an AKAI TV...Model Code #PT4250AX/SMS -
My recommendation is to call a local svc co. Since you heard a pop, it could be anywhere in the set. It requires trouble shooting to isolate where the problem is. I hope this is help-full for you.
Posted on Feb 28, 2009
SOURCE: Akai PT4298HD Rear Projection Television Problem
My AKAI 42 rear projection self focus set has blue shadows on everything and too much red, I cant seem to adjust it and self focus does not help?
Posted on Mar 23, 2009
SOURCE: I have blue ghosting in our TV picture
akai 4298HDX/SMS has blue ghosting, is there an adjustment I can make?
Posted on Aug 14, 2009
Okay, so we have the TV and it's the PTH5498, we are under the impression that it's hdtv ready but... we lost the manual so how do you turn it on??
If ur tv is a HDTV.HD tv signal u don't turn it on u have it or not.Check ur tv imcomming broadcasting signal like 1080i or 1080p.u can get that signal,if ur tv in HD broadcasting.
Apr 22, 2011 | Akai PTH5498 54" Rear Projection...
Only reddish hue color for entire screen
In most cases these CRT projection sets made by Samsung for Akai are notorious for fouled cooling liquid in one or more of the CRT's. The CRT's in most cases are no longer available.
Aug 14, 2009 | Akai PT5598HD 55" Rear Projection...
Akai 1080I
HELLO. YOU SAY IT TURN ON.? TELL ME DO YOU HEAR ANYTHING.? ANY SOUND.? IT SOUND LIKE YOU HAVE NO HIGH VOLTAGE.!!! MOST LIKLY THE FLY BACK TRANSFORMER.!!! THAT'S WHAT GIVE'S THE CTR GUN'S & THE MOTHER BOARD IT POWER.!!! NEED'S TO BE REPLACED."GOOD LUCK"
Jul 04, 2008 | Akai PTH5498 54" Rear Projection...
My TV has lines throughout the whole picture
never had this problem until we switched to hd tv service, changed it from 720p to 1080i and it helped it a little. will let uyou know if I find out how to fix it completely
Jun 30, 2008 | Akai PT5598HD 55" Rear Projection...
Akai hd projection tv pt4299hd won't turn on
Sounds like a power supply issue. Does the power indicator light up? Can you hear a click when the power button is pressed?
May 31, 2008 | Akai PT4298HD Rear Projection Television
1080i question for PT5598HD
the best from what i seen is HDMI, DVI, or comp. in that order.
On my 82" HDTV i use the VGA plug connected to P4 3.5ghz.
everything seems to come to life using a computer and good video card.
Nov 29, 2007 | Akai PT5598HD 55" Rear Projection...
AKAI 1080i HDTV 42"
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 27, 2007 | Akai PTH5498 54" Rear Projection...
Akai hdtv 1080i, No Sound
I sounds like a bad filter in the sudio supply circuit finally took out the sound output chip or the power supply that controls the sound circuit. its a soliud state set and there are no user replaceable parts inside this set. Unless you have had solid state repair experience, please be safe and call in a pro to assost you in this repair. good Luck ps Please rate this thread
Oct 19, 2006 | Akai PTH5498 54" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
