I have purchased another computer and I am trying to re-install OmniPage Pro 12, and it keeps giving me a error message of some type of "Threat Detected!" Threat name: Frojan Hores Dropper Agent.JOC detected on open. What do I need to do. I had Omni Pro on my other computer? thanks
    Novelist:
  • 210 Answers
Frozen **** are always a problem! hehe! It's possible that your new computer has a more sophisticated AntiVirus program on it, and it thinks your OCR software carries a Trojan Horse type of worm. If your Omnipage is a genuine disc, and the same disc that you used before, i'd suggest you disable your antivirus while installing the program. With Norton antivirus, you'd double-click the yellow circle/button in the system tray and then disable. Since you haven't mentioned which antivirus you have, i'll leave it to you to work that part out, eh? =-]
Posted on Aug 23, 2008
  • Steve Rand
    Steve Rand Aug 24, 2008
    Thanks for the feedback, and don't forget to turn your antivirus back on again after the installation! =-]
Dell Dimension 4550 BOOTMGR is missing error message
To repair missing orcorrupted system file/s, boot up with the Windows installation CD then -Press R to repair wheninstructed.Press 1 or Enter to repairthe C:\Windows folder.Then type chkdsk /r and then press Enter.The repair process willtake quite a long time.
Jul 09, 2012 | Dell Dimension 4550 PC Desktop
Cannot install Omnipage 18
get the old program that you have installed and click on it to get up the properties tab
click on compatibility tab
click in square and then high light win 7 click apply and ok
the fault is that you are getting the error message as you have a program already installed and if you want to install a later version of the program you will first have to go to programs and features in the control panel and uninstall omnipage program and all programs associated with the omnipage name
Jun 24, 2017 | Office Equipment & Supplies
When i try to scan, it gives me the following message "Undefined error occurred. (0x8021001F) A probably cause is that the system is unstable. Reboot the system. If this does not resolve the...
check in your scanner panel if there is any error showing like U 1 or any other message.if not then your scanner is perfect and check your system
Mar 21, 2011 | Fujitsu ScanSnap S510
OmniPage Professional 16 fails to launch
uninstall the program, reboot and then reinstall it following the instructions and on-scree commands and prompts. if the result is the same, maybe consider changing the version of your os, maybe your os somewhat conflicts with the program. try using oem os'
Jun 02, 2010 | ScanSoft Nuance OmniPage 16 Professional...
Have installation disk but have lost serial number from an old OmniPage Pro 9 program. How would I come up with serial # so I can install?
If you registered the software after purchase the manafacturer may have this information on file, and they maybe able to provide it to you. Otherwise you may have to purchase a new serial key/ software for them.
Apr 21, 2010 | Caere OmniPage Pro 9.0 Full Version for PC
In trying to install OmniPage SE onto a new computer with the vista operating system, all goes well until I come to the installation of OmniScan SE. I get the message: "The wizard was interrupted before...
Unfortunately, Nuance most likely doesn't have a Vista patch to sort the problem with Omniscan.
The best advice I can give you is to remove Windows Vista from your system and install Windows XP.
Vista is riddled with bugs and incompatibilities with many software packages and has been replaced with Windows 7 which is due to be released soon.
Rather use windows XP until Windows 7 becomes available and save yourself many further headaches.
Let me know if you would like any further assistance.
Best regards,
Graemevm
Apr 28, 2009 | Canon ScanFile OCR Full Version for PC
Cannot install omnipage se. wizard interupts process
When unistalled the previous Omnipage SE 4.0 and try to install new update vresion, an error message keep poping up saying a previous version of Omnipage is still installed in the computer and can not install the new version. No more trace is found for old version in Add/Remove screen. The problems are in the registry area. Just run regedit (export the registry as backup) and look for Scansoft under the software directory. Deleted all the Scansoft omnipage traces then restart the computer will solve the problem.
Nov 04, 2008 | Office Equipment & Supplies
ACPI error message
Hey there rcrozier, your solution is to disable ACPI in the BIOS. To do so, follow these steps. 1/ When set up is loading, a blue screen will appear asking if you have RAID devices, indicating pressing F6. Instead press and hold F7. This should prevent ACPI from installing. Alternately at the blue screen mentioned above, press F5 and hold. It should advance eventually to a new screen prompting you to press F2. Keep holding F5. It will give you another screen telling you it cannot recognize your pc type. It gives you two choices: standard pc or other. Choose standard pc. resulting in ACPI not being installed. Unfortunately the other result of this ACPI not being installed is that your power management will be reduced. Overclocking is not advised. Hope this helps. Good Luck!
Jan 29, 2008 | EPoX EP-8RDA3I Pro Motherboard
Computers & Internet Logo
David Payne
David Payne
