For most files or programs on my computer the response comes up, windows cannot open this file, to open this file windows needs to know the program that created it. It gives two options to either use a web service which gets me no where because I cannot download anything, and to select a program in the list is impossible. Can you help please
  • 1,498 Answers
Hi shepand kate,
Each file has an extension that tells windows what type it is. There is an index file that cross references this extension with what to do do with it when you do something to it. Like execute, or Open. If it's Open, It keeps track of what program opens it.
If possible, run Explorer. From the menu bar click Tools. Select Folder Options. Click the File Types Tab. This is where this index is accessed.
Get back to me when you find it.
Mike
Posted on Aug 23, 2008
  • 435 Answers
Which type of file do you want to run or play???
  • Narmada Anand
    Narmada Anand Aug 23, 2008
    If you open a file with 3gp extension then you could not use windows media player.For this type of file you need Quick Time Player(QTP).When you dont have QTP then that 'select programme' dialog box will appear.This above mentioned was an example.....
  • Narmada Anand
    In short, A particular file extension which cannot be played by any player or installer, then this box will appear, asking you for an alternate player and I dont think this is a virus as this is usual...
    Thanks
    Master:
  • 848 Answers
There may be virus in your pc ...so just check for virus in it ....due to virus you will get this kind of problem .....
SOURCE:
.fxp is not an object file
For additional information click the following link: https://www.fixtoolbox.com/dbffix.html
DBF Fix Toolbox
Also you can try to follow these steps:
    1.Click on Start and then Control Panel. 2.Click on the Programs link.
    Note: If you're viewing the Small icons or Large icons view of Control Panel, you won't see this link. Click on the Default Programs icon and then click on the Associate a file type or protocol with a program link. Then proceed to Step 4.
    3. Click on the Make a file type always open in a specific program link under the Default Programs heading
    4. In the Set Associations window, scroll down the list until you see the file extension that you want to change the default program for.
    5. Click on the file extension to highlight it, once you've found the one you're looking for.
    6. Click the Change program... button above the scroll bar.
    The Open With dialog box should appear.
    7. Look through the options in the Recommended Programs area and choose the application that you want to open the file extension with when you double-click on the particular kind of file on your computer.
    Note: Chances are, the applications listed under Recommended Programs will contain the most applicable programs for this file type but be sure to look at the applications under Other Programs. You may need to click the v to expand the list of these programs.
    Note: Click Browse... to search through your computer for any program not listed that you'd like to use.
    8. Click the OK button on the Open With window. Windows 7 will refresh the list of file associations to show the new default program to open this type of file.
    9. Click the Close button at the bottom of the Set Associations window. You may also close the Control Panel window if it's still open.
    10. From this point forward, when you double-click on any file with this particular file extension, the program you associated it with in Step 7 will launch and load the particular file.
    Important: Whatever program used to automatically open when these types of files were launched will still open these types of files. To use another program, you'll just need to start the program manually and then browse your computer for the particular file.
Nov 12, 2015 | HiBase DBF Viewer 2000
Emachine will not run anything
Rundll32.exe errors typically occur in response to the inability of Windows to access an application, program or file as the result of a corrupted or missing DLL (Dynamic Link Library) file or in response to a rundll32.exe virus that has been designed to look like a normal Windows process.
Here are the easiest ways to fix rundll32.exe errors.
Click "Ctrl + Alt + Delete" on your computer's keyboard to open the Task Manager window.
Click the "Processes" tab and search for a rundll32.exe program.
If one is running and appears to be accessing a lot of your system's resources, click "End Process" as it is likely a malicious program and not a true Windows program.
Run software to seek out, detain and remove viruses, malware, spyware and adware. Often these malicious programs corrupt DLL files or cause them to be deleted or moved and, as mentioned, some rundll32.exe programs may in fact be viruses on your system.
Reboot your computer to update any changes you may have made recently to your files and programs.
Many programs and applications require a reboot for successful installation.
Uninstall a recently installed or changed program or application and then reinstall it using the default settings.
An installed program may not have loaded properly, an installation via the Internet may have been interrupted enough to create errors or the program may have a bug.
If you uninstalled a program and see a rundll32.exe error, reinstall the program and then uninstall once more.
Retain the services of a Microsoft certified technician, if all else fails, to review and fix your system's Registry.
Dec 01, 2013 | E-Machines Computers & Internet
Aspire 5750 keeps showing a message There is no associated program to perform the requested action and will not operateon windows 7 Home Premium. What can I do? . What can I do
What type of file are you trying to open? Are you trying to watch a movie, open a document that was written on an older computer, or some other file?
If the software that should open the file is on your computer but not associated with that file type, right click on the file and choose Open With > Choose default program. Then Browse through programs on your computer (Program Files and Program Files (x86) and their sub folders). Alternatively, click Start > Control Panel > Programs. Under Default Programs, select Make a file type always open in a specific program. Scroll down to the extension and add a program for it.
Many computers do not come with all the software you might want. In that case, you will need to get the software or a plug-in to add to your software. For example, a computer with a Blu-ray optical drive may not have the Blu-ray player software. Office files may have similar limits. (WordPad reads Word files; Excel and PowerPoint viewers aren't always included.)
I hope this helps. Please add a comment with the file type you need to open for specific program suggestions.
Mar 21, 2013 | Acer Aspire 5750 15.6 inch Laptop Intel...
Cubase 4.0.1 won't run under Windows 7
Try to reinstall the applications responsible for the error:
-- It may happen that any program is responsible for the error as one of the main causes is software malfunction. So, reinstall the program by following the below steps:
-- Go to Start-> Control Panel->Add/ Remove Programs -> choose the program that needs to be reinstalled from a given list and click on Uninstall button.
-- Then after, restart the PC in order to refresh the system setting and make a fresh installation of the program.
Replace the Synsoacc.dll existing on the system:
In case of file corruption, you need to replace the file with new one as it can help you in the error resolution. To do this, follow the below steps:
-- At first, connect online and download a fresh file to save in the computer's memory
-- Browse to c:\Windows\System32 to find the existing file on your PC and rename it to synsoaccBACKUP.dll.
-- Now go to Start-Run and type cmd to open the command prompt.
-- There type the command regsvr32 synsoacc.dll to finally replace the file.
Nov 18, 2011 | Steinberg Cubase 4 ( Windows / Macintosh )...
Get fliptoast off my computer
If you are trying to uninstall the application Fliptoast used with/for Facebook then depending on what version of windows you're using (assuming you're using windows) go to: Start, Control Panel, Programs and select uninstall a program. Then find Fliptoast in the list and uninstall it from there.
If this does not remove it you can try a program call CCleaner and you can download it from here.
Once you have this program installed open it and go to Tools and Uninstall. Find Fliptoast in the list of applications, select it then choose Run Uninstaller.
Feb 28, 2011 | Computers & Internet
My problem! is when i want to open a file my pc
this is happening when the file association with the program is not made...either the program for that file to be open with is not present...or the file was transferred into the computer and you never had this kinda files before and first time you have to choose a program to open the file with...
in this 2 cases you have to know the type (format ) of the file and browse...choose my computer ..than C drive .../program file...and there choose the suitable program for the file...
and from then on ...the files of that kind will be opened with that program...
if you do not know what program to choose...let me know the file type...(look at the properties by right click on the file and choose properties..there will be at least the abbreviation of the file type..)
and with the name of the file format ..I will look for a program or ..tell you what program to choose for it ..
Another thing that might been happening .(in case that the computer makes this request for all files when yo are trying to open them ) ..is that you been hit by a virus that affected the file association feature ...and you will probably need to reinstall the operation system to be sure that this is removed for good..(format the C partition during the install)....
Or ...if your computer remember the program just as long it is running and after restart is doing the same ...in this case the Bios Battery is dead or not making the correct contact ...and the computer do not remember the associations choices and it need to be changed....this can be easy recognized cause a side effect is the clock will not be on time...but get to the bios manufacturing date..and 0 hour each time you open it ..in this case change the bios battery ..and it will remember the settings...all you have to do is to re-associate the file one more time after changing it .. accurate ..
Apr 28, 2010 | Microsoft Windows XP Professional for PC
Windows cannot open file. to open this file,windows needs to know what program created it. Windows can go online to look it up automaticaly or you can manually select from a list of programs on your...
You will need to know what program the file was created in. For example...If I were to send you a file with doc at the end of it you would need Microsoft word installed on YOUR computer to be able to open the file. Get in touch with the person that is sending you the file and ask them what program they created it in. Then you will know what program you need to install on your computer.
Hope this helps.
Jul 10, 2009 | Battery Technology for Acer Travelmate...
Problem opening some attachments
You need to tell Windows what program you want to use when opening the file since you don't have any program installed that knows this file.
Do you know what kind of file it is? If not, you need to find this out.
Usually you get powerpoint or pdf files in your mail. To read these you need Adobe Acrobat Reader or Microsoft Powerpoint Viewer.
Short, You need to install a program that can handle the files you get in your mail. What program depends on the file.
To know what kind of file it is you have to se what "extension" it have (the three letters after the dot). Normaly you don't see this, but to be able to see it open Explorer and do go through the following:
  1. select Start -> Settings -> Control Panels -> Folder Options
  2. select the View tab
  3. check "show hidden files and folders"
  4. Uncheck "hide file extensions for known file types"
  5. Click OK to finish
Now, save the file on your desk and check the last letters of the file. If it ends with .pdg it's a pdf-file, if it ends with ppt it's a power point file.
If it ends with something else, it needs a different program. To know which, just ask again :)
Apr 07, 2009 | Microsoft Windows? Vista Home Premium...
Word & Excel won't open files when doubleclicked in Windows Explorer
reinstall - there must be administrator issues on your computer.
Oct 29, 2008 | Microsoft Office 2003 Basic Edition...
Open Questions:
Aol mail help!~18OO8O31-O69 @# Usa AOL USA phone number is ranked #2 out of 2 because 7,728 AOL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO::8O31069 is to reach t he AOL USA Technical support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, AOL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AOL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AOL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AOL USA Calling AOL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AOL USA Technical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AOL USA's Technical support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AOL USA's phone numbers against each other. Contacting AOL USA in General While I8OO8O31O69 is AOL USA's #2 most popular phone number, it's not the only way to get a hold of their technical support team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AOL USA help by calling them, is that other customers give their technical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AOL USA.
Oct 19, 2019 | AOL Computers & Internet
SBCglobal MAil NuMbER {1-855*536*5666}#[email protected] UTAH This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 19, 2019 | Best Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
