Question about Ruud UBHC Air Conditioner
Help on my ac unit
We are buying a house with a ruud upka-030jas ac unit. we have tried to turn it on. it blows the fan on in the inside of the house but the outside unit does not come on. there is no manual that we have found. is there a special trick or may something be wrong?
alyson capone
model# upka-030jas
serial# 4919 m2293 073
    New Friend:
Access the compressor common, start, run terminals. Disconnect the wires from them and test them with an ohm meter. You should have a measurable resistance between each terminal and infinite from any of the terminals to the compressor case. If that is good you want to check if you have a starting relay if the relay is bad the compressor will have very high amps and then go off on either the thermal overload of circuit breaker.
Posted on Dec 17, 2012
  • 3 Answers
Bad capacitor or low pressure switch or maybe safety switch on condesate pump or ptrap
Posted on Jun 04, 2012
Check if you are getting 24 volts to you contactor coil on your condensing unit. If you are that means your problem is in your condensing unit check voltage going to your condensing unit it will be usually 208 to 230 v.
Posted on Aug 25, 2008
  • 182 Answers
No special tricks alyson.....prolly just a breaker or fuse.check the main panel for a turned off breaker and at the unit there's a disconnect box that may have a bad fuse.
Posted on Aug 23, 2008
"I have a 13 year old 10 SEER Achiever RUUD UPKA-049JAZ heat pump when you turn the AC on the ouside unit makes surging sound about every 3 min after about 45 min the ac will kick on."
sounds like compressor is going bad .. first try a hard start kit.. have staved off replacing compressor many times.. may last a long time may last 1 day
also check charge
May 20, 2014 | Ruud Heating & Cooling
It making a humming sound and the fan is going around slow the temp in home is 74 the set temp is 65 so it should not be running what could be the problem ruud upka-035jak is model
If you are running A.C.,and the T-stat is set at 65,and the room temp is 74,the A.C. will run until the temp goes down to about 65 or so.Turn T-stat to 76 and the unit should shut down. Also,check furnace filter for dirt, and check condensor unit coils and see if they are dirty.If condensor coil is dirty it cannot breathe properly. That will cause the compressor, and the blower motor to overheat.Wash cond. coil down with water hose to clean .Start at top of coil and go sideways,slowly going down.
Feb 23, 2010 | Ruud Matching Split Air Conditioner
The inside RUUD AC unit has ice and no cold air is blown
it is likely low on coolant or as some say "freon" that or the indoor fan motor has not run properly. let it thaw completely by shutting it off and just turning on your fan switch from auto to the on positon. if you begin to feel air flow eventually you need coolant added b/c you probably have a leak from the system being old
Sep 13, 2009 | Ruud UBHC Air Conditioner
No air blowing inside the house thru vents;starts fine than stops
You are likely low on charge and the unit is freezing up. You need some with gauges to check. You should not try to run this unit until then or it will burn out the compressor.
Jul 18, 2009 | Ruud Central System Air Conditioner
No cold air blowing from RUDD UPKA_)$#JAZ
A few things to check; Clean filter, make sure none of your ducts have blown loose in attic area, or under house. If neither problem exists check to make sure your compressor is kicking on, it makes a deeper toned noise than fan motor. If it's not coming on, call A\C company, preferably the installer to check it out. Good luck.
Jul 10, 2009 | Heating & Cooling
1990 model RUUD AC unit. Fan runs, no cooling
Is the outside unit running? Fan and compressor?
Jun 29, 2009 | Heating & Cooling
The outside unit on our Ruud heat pump won't turn on. The inside fan blows but the unit outside sits idle - no fan turning, nothing. It was cooling earlier today, but when I came home from shopping, the...
first look for red button neer the copper line set if has one push it second inspect thermostat wires for weed eater damage check disconnect for fuses check breaker at main panel pull disconect and remove cover check stat wire connections look at the capacitor if swelled up on top bad if all look ok put disconect in using insulated object manually push in contactor if unit comes on check for 24 volt ac on yellow stat wire to common if none stat wire could be loose at indoor unit or stat bad hope this helps you
Jun 05, 2009 | Ruud UPMC036 Air Conditioner
OUTSIDE FAN RUNS CONSTANTLY, I HAVE A RUUD UAHE 030JAS SERIAL NO 4009 M1892 9647
Check your thermostat in the house and make sure you have the fan switch selected to AUTO mode and NOT the ON mode..
Sep 01, 2008 | Ruud Heating & Cooling
Ruud UBHC Air Conditioner Logo
222 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
