Transmission slipping - Washing Machines
  • Anonymous Mar 11, 2009
    at about 35 -45 it slips alittle
    Genius:
  • 1,028 Answers
Doubt it's the transmission probably the coupling between motor and transmission is broken or possibly rounded out and slipping on shaft
Posted on Aug 23, 2008
Trans acts like it's in nutreul and the speedometer will to zero
Why Is My Automatic Transmission Slipping? If you have an automatic transmission and it "slips" while you are driving it-that is, the car engine revs without the power going to the wheels-the most common cause (though not the only possible cause) is low transmission fluid. If the slipping is caused by low fluid, it will get worse as the transmission gets hotter.
Why Is My Manual Transmission Slipping? A standard ("manual") transmission uses fluid too, but leaks aren't a common issue; a standard transmission could lose all its fluid and never slip at all, though eventually it would lock up while driving down the road. If you have a standard transmission, and it's slipping-the engine revs but it doesn't transmit power to the wheels-the problem is usually in the clutch.
Further down in the article I discuss how to diagnose this problem.
Sounds Like Low Transmission Fluid to Me
Sep 29, 2016 | Cars & Trucks
Gears slip
www.aa1car.com/library/transmission_slipping.htm
Transmission slipping may be caused by several things: ... there must be enough fluid to generate the internal pressure required to engage the various gears.
Top 10 Signs of Transmission Trouble - HowStuffWorks
auto.howstuffworks.com/under-the.../5-signs-transmission-trouble.htm
It may happen when trying to get into first gear from a stop, or at any point up and down the assorted gears. Common causes include low transmission fluid, ...
10 Most Common Transmission Problems
www.transmissionrepaircostguide.com/10-common-transmission-proble...
A clunking sounds when you shift gears almost always lies within a .... If the transmission is spontaneously slipping in an out of gear (or simply popping into ...
Transmission Slipping - Transmission Repair Guy
Jan 01, 2016 | Cars & Trucks
Transmission not shiftin
For car not changing gears it can be shifter assembly issue, or it can also be transmission issue. Get the shifter assembly inspected with ignition OFF.
For more troubleshooting, I suggest you to get the Following help link checked, its complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
TRANSMISSION GEARS SLIPPING AND FLUID LEAKING ISSUES
Transmission gear assembly and transmission needs inspection. Also check the transmission fluid level. Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot this problem.
I suggest you to refer these links.
Click the link below:-----
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping?
http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem?
http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating?
http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Transmission fluid leaks near radiator on ford windstar?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Ford Windstar transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
These details will help.
Thanks.
Feb 15, 2013 | 2002 Jeep Grand Cherokee
Replaced 2 3 sol in trans goes forward in all gears
TRANSMISSION REPLACING AND TROUBLESHOOTING
http://alltypesofpartsreplacing.blogspot.com/2012/12/transmission-replacing-and.html
Thanks.
Dec 07, 2012 | 2005 Pontiac Grand Am
1986 olds 88 trans slipping
Transmission gear assembly and transmission needs inspection.Also check the transmission fluid level.Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot these problem.
2000 Toyota Camry: Transmission slipping and Stuck up? http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear? http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping? http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping? http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem? http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating? http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
Ford Windstar transmission fluid leaking? http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
Thanks.
Nov 24, 2012 | Cars & Trucks
Trans starting slipping after modulator replaced
Thanks.
Nov 24, 2012 | 1986 Oldsmobile Delta 88
2001 Audi A4 Quattro, Reverse slips
Perhaps it is in severe pain, because you failed to identify it it by make and model!
May 15, 2017 | Cars & Trucks
Servo or band worn out, o.ring gone hard or clutch pack burnt out.
May 14, 2017 | Cars & Trucks
94 Pathfinder, Manual transmission slipping a tiny bit. I want to add Lucas Stop Slip. How do I do this. Theres no Dipstick to check levels of TRANS FLUIDS
Adding Stop slip to a manual transmission with not keep your clutch from slipping. Replace or adjust the clutch.
Mar 13, 2010 | 1994 Nissan Pathfinder
Transmission slipping in drive and transmission whining.
SOUND LIKE TRANSMISSION IS SLIPPING.CHECK THE TRANSMISSION FLUID MAKE SURE ITS NOT LOW.ALSO IF TRANSMISSION FLUID LOOKS DIRTY DARK AND SMELLS BAD REPLACE FLUID AND FILTER.IF FLUID IS GOOD YOU HAVE.TRANSMISSION OIL PUMP AND FORWARD CLUTCH PROBLEMS.
Sep 04, 2009 | 2000 Dodge Caravan
Washing Machines Logo
216 people viewed this question
Top Washing Machines Experts
