Question about Canon PowerShot A640 Digital Camera
A640 Lock-up Hi, The camera was working fine up until today when I took it out of the case, it was stuck, locked-up somehow. I haden't used it in a couple of days (had never had a problem with it before), and now, the only sign of life when pressing the ON/OFF button is the small green light underneeth turns on but nothing else powers up or happens. The only way to get the green light off again is to take the batteries out. Also, the lens is stuck open, and the zoom partially out. What should I do? Has this camera taken it's last picture...or is there hope? (Also, I'm currently living/traveling abroad and don't have my original box/receipt with me.) Any help would be GREATLY appreciated..!
  • ajrovig Jan 30, 2009
    Where is this OTHER battery located?
Take out the OTHER battery, the one that maintains the date / time and then the camera can 'reboot' cleanly when you put some fresh batteries in it.
Posted on Jan 03, 2009
Door lock and will not open once you unlock it.
its more than likley the solinoid that controls the lock itseilf.
try removing the door lock fuse,
you should be able to use the lock manually untill you get a new solinoid,
good luck,Gary
Oct 24, 2013 | 2003 Chevrolet Silverado 1500
'91 LS400, trunk will not open. key will not turn, electric latch switch clicks but won't open. valet lock in open position. Tried 1) disconnect battery, reconnect battery, use switch, push down on...
If you hear the sound of the electric latch switch, then it's working but stuck somehow. Just put the key in the switch and turn it to the right and then pull up the trunk or ask someone to help you. it will open. I tried it today and it opened with me. It was stuck from inside by some kind of a broken plastic pieces. Just removed it and now it's working fine. good luck
May 26, 2011 | 1991 Lexus LS 400
Camera says that my sd card is locked and it isn't
try to put some glue on a your card lock , in unlock position. But be carefully do not delete your picture by accidentally.
May 31, 2010 | Canon PowerShot A710 IS Digital Camera
I cannot get my lift gate to lock all of the other doors lock I can't even lock it with the key can you help me?
your tailgate lock is rusted up try some lub spray oil,if this does not work replace lock.adrian;;;
Nov 23, 2009 | Ford Excursion Cars & Trucks
CANON POWERSHOT A640 LCD VIEWFINDER STOPPED WORKING
nice camera ... the button at the bottom left is marked Disp ... each time you push that button it will change the display mode ... there are three modes .. OFF, ON , and NIGHT ... night turns down the brightness a bit ... push the button several times until you get the display you want ..
Oct 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera having error WARNING FOCUS LOCK
Hello there! Focus ring lock means that some how the focus ring is not turning freely. If it turns easilly then inside the optocoupler unit which reads out the movement of ring must be dust or damage.in the flexicable. Therefore somehow the camera should be disassembled got cleaned by pressurized air in case of dust and reassembled and hopefully it should work without problem.
Aug 12, 2009 | Panasonic AG-DVX100 Mini DV Digital...
LCD Screen not working, but camera still takes pictures
Looks like the contacts of the LCD of your camera are loose. Be advised that this repair would require you to take it apart and may vvoid your warranty. If there are no faulty contacts then you will have to replace the LCD screen. Should cost you around 100-150$
Nov 14, 2008 | Canon PowerShot A640 Digital Camera
Canon A640 thinks media card is lock
Inside your camera there is a detector that senses that your card is locked or not it sounds like yours is stuck in, you may be able to free it get yourself a flash light and look inside the socket on the side where the slide is on the memory card use a very small tool or paper clip you have to be really careful when doing this you could break the sensor if your to rough on it.Good luck
Jul 29, 2008 | Canon PowerShot A640 Digital Camera
Canon A640 flash problem
I sent my camera into Canon for repair. They said the flash was malfunctioning, and there was something wrong with the flash exposure control. The repair cost about $87. It took approximately 10 days from the time I sent the camera in until the time I got it back.
Jul 11, 2008 | Canon PowerShot A640 Digital Camera
Canon PowerShot A640 Digital Camera Logo
110 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
