Question about SanDisk Sansa m240 MP3 Player
Up date time
There was a DROP MENU STATING GO ON THE NET TO AJUST THE CLOCK TO ENABLE PLAYING MUSIC FILES.
  • 8,596 Answers
Sounds virus-related. Do this first:
To format the player directly, follow these steps:
1. Press the Home button to return to the Main Menu.
2. Select Settings from the Main Menu.
3. Select System Settings.
4. Scroll down to Format and select it.
5. Select Yes to start formatting.
If that fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 10, 2008
How to change from military 24 hr to regular 12 hour on iMac
If you have the time shown in your menu bar click on it, and select "Open Date & Time from the drop-down menu. If not, you will have to open System Preferences, (found in the Applications folder, and probably in the Dock, also.) Once you launch System Preferences, click on Date & Time Preferences and you should find three clickable menus (Date & Time; Time Zone; Clock.) Under "Clock" you should find a checkbox labelled, "Use a 24 hour clock." Deselect it. You're done. Easy!
Aug 25, 2014 | Apple iMac Computers & Internet
I have a small alarm clock with model # alck-487 and three buttons M, S, D. i can't find the right combo of push and/ or hold to change the time. can you assist?
ALCK-487 reset time:
Press M three times, you will see the seconds flashing.
Then press S once to adjust minutes, press D,
press S a second time to adjust hours, press D,
press S a third time to adjust date of month, press D,
press S a fourth time to adjust month, press D,
press S a fifth time to adjust day of week, press D,
Then press M to end settings.
Mar 11, 2014 | Audio Players & Recorders
Explain how to set the date in the bottom right corner of my computer screen
  • Double click the time display on the bottom right of the computer screen to open the date and time properties box. Use the tabs to access settings for time, date, time zone and Web-based time updates.
  • 2 Set the clock for the correct time zone. Click the "Time zone" tab. Click the drop-down menu for time zone choices. Click the time zone choice for your area. Click a check in the box for automatic updates on daylight saving time changes. Click the "Apply" button, then the "OK" button.
  • 3 Set the correct date. Click the "Date and time" tab to show clock and calendar settings. Click the drop-down menu displaying the name of a month to change the month. Use the up-and-down arrow keys to change the year being displayed. Click on a date on the calendar image to set the date. The time can be manually set on this page also.
  • 4 Set the current time. Use the up-and-down arrow keys next to the numeric time display on the date and time page to manually set the clock. Click "Apply," then click "OK" to confirm date and time settings.
  • 5 Click the "Internet time" tab to use a Web-based clock for updates to automatically correct the time. Click the "Server" drop-down menu for listed Internet time sources. Click a check mark into the check box for automatic synchronizing. Click the "Update now" button, then click the "OK" button.
Sep 12, 2011 | Dell Dimension 4700 PC Desktop
How do I enable the date to show on my Canon powershot 470?
The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard". Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again
Jan 20, 2011 | Canon PowerShot A470 Digital Camera
My mail box won't open.When i try to check my mail a box shows up stating that my mail box will not open,due to browser or firewall?????
May you can try this :
1. The date on your computer needs to be set properly -- double click the clock verify that
the time and date are set.
2. Clear your IE cache and cookies -- open Internet Explorer, click the Tools menu, then
Internet Options, then click the Delete Files button, and when that's complete click the
Delete Cookies button.
3. Check your IE Security settings -- open Internet Explorer, click the Tools menu, then
Internet Options, then Advanced tab, scroll to the Security section, and verify that "Check
for server certificate revocation" is unchecked. Also verify that 'Use SSL 2.0' and Use SSL
3.0' is checked, then click OK.
4. Click Start, then Run, and enter the following:
regsvr32 softpub.dll
then click OK
5. Restart messenger and IE
Jan 18, 2010 | Yahoo Mail
As soon as you turn on the music on the 10th second it changes song same with all music and also the date and clock won't stay programed. Cybertec MP4 Multimedia Player
that happend to me!!! it sucked but after a long time i figures it out
press the menu bottom while playing a song, go into the repeat option, and put it in normal, it is probably set in INTRO
thats why that happens
Nov 10, 2009 | Audio Players & Recorders
Playing music on htc hero from itunes library of macbook
One issue should go first ahead of your question --- is the music you want to transfer from iTunes DRM-protected?
1. If they are non-DRM .mp3 or .m4a, you can either use one-stand free iTunes transfer like DoubleTwist or iTunes Agent which dose good job of transferring iTunes music to HTC Hero; or you can manually frag and drop by following those steps:
Step 1. Plug in your phone via-usb to Windows Computer
Step 2. From the "HTC HERO Phone" pull down drop-menu from the top and select with your finger the menu that says "USB Connected Select to copy files to/from your computer.
Step 3. Select Mount ("on the phone")
Step 4. The Default Windows Removable Disk shows up (on the computer), select open folder to view files. Here you will see the phones & applications file structure.
Step 5. Select the file that says DCIM then 100MEDIA this is location for your music, pictures, and videos.
Step 6. Open up My Computer or Windows Explorer in a seprate window on the computer and copy and paste your files into the 100MEDIA location.
Step 7. Final step, from the phone pull down the drop down menu from the top and select Turn off USB Storage - Turn off - you will see SD Sync.
2. If they are DRM-protectd .m4p music .m4v video files or other protected .wma wmv files, a 3rd party DRM Removal Software is a must-have tool to strip DRM license and convert format to HTC supported .mp3 audio and .3gp video.
Transferring is as easy as what was stated above.
For detailed info, you can check the following tutorial:
How to sync iTunes Amazon music video DVD movie on HTC Hero Touch HD, Pro, Diamod etc
Sep 21, 2009 | HTC Hero Smartphone
Clock slow
Set the date and time To set the date and time displayed on the BlackBerry smartphone, complete the following steps:
  1. In the Clock application, press the Menu key.
  2. Click Options.
  3. Click Set Time.
  4. Set the date and time.
  5. Press the Menu key.
  6. Click Save.
Retrieve the date and time from the wireless network To retrieve the current date and time from the wireless network, complete the following steps:
  2. Click Options.
  3. Click Set Time.
  4. Set the time zone in the Time Zone field.
  5. Perform one of the following actions:
    • To retrieve the date and time from the wireless network that your BlackBerry smartphone is connected to, change the Date/Time Source field to Network.
    • To retrieve the date and time from the BlackBerry® Infrastructure, change the Date/Time Source field to BlackBerry.
  6. Press the Menu key.
  7. Click Update Time.
  8. Press the Menu key.
  9. Click Save.
Note: To set the time manually, change the Date/Time Source field to Off.
Sep 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
Setting clock
First select calender press enter. to set date press stop then use < arrows > to set year, up and down to set month, press stop to comfirm. Then use navigation buttons to select cuarrent date and press enter to confirm. To exit press menu button.
Use nav buttons to select clock, press enter to confirm the clock display will appear.
To set clock press menu for custom set up. Use down arrow key to find "set time" right arrow to kighlight set time press enter, then arrow keys to set time then enter then left arrow all the way to the left then down to exit, athen enter.
Hope this helps.
chuck32
First hit setup then find settings, then enter. Use arrow keys to change time, then enter
Feb 03, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Problem playing music files with new Goodmans mp3 player (GMP34G5)
i got mine about an hour ago and it works fine. don't drag and drop music files, sync them to the mp3 player using windows media player.
Dec 02, 2007 | GPX ML848B Digital Media Player
SanDisk Sansa m240 MP3 Player Logo
18 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
