Cartridge error problem
I tried wiping the cartridge and the bar clean. didn't work. I am still getting a cartridge arror read on my Lexmark 6150. Help!
  • samjackmatt Aug 23, 2008
    The two solutions did not work. Still need help
    Novelist:
  • 210 Answers
Please see your first thread regarding my next suggestion.
In short, it could be the cartridge itself. Remove the colour and retest with just the black. =-]
Posted on Aug 23, 2008
My black ink all of a sudden won't print and I get an error message that says remove tape from cartridge...there is no tape...it is a Lexmark 6150
If the problem continues even after re-seating the black cartridge and cleaning its nozzles, then it could be a faulty cartridge issue. Replace it with a new genuine Lexmark cartridge.
Aug 23, 2011 | Lexmark X6150 All-In-One InkJet Printer
Cartridge error on Lexmark 6150
Try first unplugging power and usb cable.
Removing cartridges, putting them back and restarting.
Aug 22, 2008 | Office Equipment & Supplies
Won't print reads error code 50c
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 31, 2009 | Lexmark X6150 All-In-One InkJet Printer
Lexmark x3330 Error message
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
Next, try this printer self-test by following the steps given below:
1. Turn off power.
2. Press and hold the "Black Copy" and the "Power" buttons at the same time. Continue holding then until the screen displays "Mfg Menus Enabled."
3. Press the "Menu"(--->) button 2 times.
4. Screen will read "LCD Button Test," press "(-)" button 2 times.
5. Screen will read "Single Test Page," press the "Menu" button once.
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 6150 printing problem.
Have you try replacing your cartridge ???
Mar 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark error message hardware error 0502
Clean the rollers that the cartridges run on with a non-lint wipe (i use non scented baby wipes for all my printer work. The printer should now run fine. cheers lilacgerry xxx
Jan 21, 2008 | Lexmark X6170 All-In-One InkJet Printer
6150 Lexmark
is printer Cartridge new? if now try to purchase new cartridge. If it doesnt work your print cartrige is the problem.
Jan 17, 2008 | Office Equipment & Supplies
"Cartridge Error" in the display.
I got this from Lexmark this morning didn"t work for me but it may help somedody else worth a try C/P. You need to clean NVRAM on Lexmark P6250 printer. Please find below the steps to clear the NVRAM on the Lexmark P6250: 1. Press the "Up" arrow and "Menu" button at the same time. 2. Press the down arrow until the LCD displays "Clean NVRAM." 3. Press "Select."
Nov 30, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark 5150 - Error 0502
I have had this problem "Hardware Error 0502" which kept getting worse until I could not print any more. So I open the cartridge cover & removed both good cartridges, pushed the cartridge carrier fully to the right hand side & with one slightly damp cloth, a dry cloth & a pair of latex gloves (as the ink stains your skin) I first carfully cleaned the guey head like things on the bottom inside the printer on the left hand side. I removed a load of hard & soft gue with the damp cloth then finished with the dry cloth. Next I cleaned the bottom track aswell, moved the cartriage carrier fully to the left hand side to clean the rest of the bottom track. I then re-installed both cartriages & the printer is now perfect again!
Oct 26, 2007 | Lexmark X5150 All-In-One InkJet Printer
50 people viewed this question
k24674
jasbo
jasbo
