Question about Hobart AM14-253 Free-standing Dishwasher
Programming the 00-749825 Control Board on a Hobart AM14C
I replaced the defective control board on a Hobart AM14C. How do I enter the programming mode and set the correct functions for our machine.
  • Anonymous Mar 16, 2014
    replace control board assy buut needs to be program to work with am15vl dishwasher
    Hobart am15vl control board asst needs to be program from hl to vl
  • 49 Answers
That board comes with directions. if not go to hobart and have them copy you one out of a new boards box
Posted on Sep 30, 2008
  • Dennis Perez
    Dennis Perez Dec 13, 2012
    Press the program button on the board and then press the on button until the timer counts down on the read out and your into the prgramming function on the display.
How to check for a bad sensor on my MFI2569YEWO maytag fridge? We've replaced the control board in the back and display board in the door. the display reads PE0 000. Can't get it to program. HELP ME!
Patti when you change the main control board you have to reprogram the refrigerator to understand the board there is a code just below the model number and here are the instructions you need to follow them carefully
Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word "Code."
1. Press and hold the Door Alarm Keypad .
2. Press and hold Freezer Temperature Down Keypad within 3 seconds .
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more.
6. The control will display the current Program CODE. This value should be validated with the Program CODE printed on the unit serial plate. NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved. NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).
Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated. The Programming mode can be exited at any time by pressing Door Alarm key for 3 seconds or will exit if unattended for four minutes.
http://www.appliance911seabreeze.com/
Aug 09, 2016 | Maytag Refrigerators
Rinse temperature too low
your right dont guess the board is bad!
Aug 08, 2012 | Hobart AM14C-155 Dishwasher
Reprogram control board after replacement/ MFI2266AEU B/M REFRIGERATOR, M'TAG
Press and Hold Door Alarm Keypad
Press and Hold temp down keypad
Relaease door alarm Keypad and wait 3 seconds.
The control will display PE to indicate Programming mode.
Entry to programming mode confirmed by pressing FREEZER temp down keypad once more
The control will display the Current unit Programming Control code This code must be validated by comparing it to the Programming code stamped on the unit data plate (Model number plate)
If the programming code is correct all you have to do is close the refrigerator doors
To change the CODE press the REFRIGERATOR up or down keypad to change the digits.
To move between digits press the FREEZER up or down button. Decimal point indicates selection
Once the desired code is entered PRESS and HOLD the freezer temp down button until the CODE entered starts flashing.
Close the refrigerator doors or wait 4 minutes without Kaypad input for programming mode to exit.
That should be what you needed.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Maytag MFI2266AE Side by Side Bottom...
Hobart dishwasher am14 displays 255 in temp window heater wont fire
The wash thermistor is shorted. The float and probe assembly in the wash tank should be replaced.
Jun 13, 2010 | Hobart AM14C-155 Dishwasher
Is there a reset switch? Power won't turn on.
no there are no resets on this d/w. open the control box door, ck. the fuse's inside on the trans. and on the control board. if any are burnt replace, you need to find out where you are losing your voltage,by using a meter
Jul 04, 2009 | Hobart 42 in. AM14C-154 Free-standing...
No heat on rinse cycle HOBART AM14C Dishwasher
3 Con, is the booster heat contactor. If it is chattering, the fault will be in the booster. There are a few different boosters in the AM14. can you post the ML number from the data plate, or describe if the booster is a square Hatco HCM-10, or a round stainless booster with a 13 kw multi wired element.. All boosters use a low water cut off circuit, a high limit thermostat and a control thermostat. The old Hatcobooster uses mechanicqal components, where the new rount tank uses probes and a control board. The board has 3 leds. red is calling for heat, yellow is open thermistor, and green is shorted thermistor.
AM14's had a variety of different control circuit voltages, ranging from 240/208/120 and 24 volt AC. Check the transformer secondary for correct output to controls, trace through circuit until voltage pulses. If new style, it could be just scaled up probes not reading water. Drain the tank with the power off before removing probes.
Jul 03, 2009 | Hobart AM14C-155 Dishwasher
No rinse cycle
If it is new, would you not call Hobart for a warranty call? 1-800-444-4764 to reach the nearest branch in Canada.
Seeing it's new it is most probably not programmed correctly. On the control board is factory jumper J5, short thse two pins and press ON on keyboard. when the display shows ty remove short. pressing select on the CB will change the options, pressing up arrow will incriment the change options. first setting is machine type= AS,second is id, hot/cold or plain AM15 only, select H,C,or P.
3rd is tc,auto temp control. The rest will not affect your condition. Press OFF on keyboard to save and exit.
Jul 03, 2009 | Hobart 29 in. AM15-1 Free-Standing...
For a HOBART AM14C I have a faulty ccc (294551B). I received CCA (749825) Did I receive the correct board? They do not look even remotely the same.
HI,
ACCORDING TO THE SPECS IVE SEEN ON BOTH BOARDS YOU ARE CORRECT THEY ARE NOT THE SAME BOARDS AND THEY DON'T CROSS REFERENCE TO EACH OTHER EITHER I WOULD RETURN THE BOARD TO GET THE CORRECT ONE.
HOPE THIS HELPS GOOD LUCK.
Mar 30, 2009 | Hobart AM14-253 Free-standing Dishwasher
Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
Dec 31, 2007 | Kenmore 53642 / 53644 Side by Side...
Hobart AM14-253 Free-standing Dishwasher Logo
777 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
