Question about Alpine CD Player CDA-9855 LIMITED QUANTITY ACT NOW
Display My screeen went dark after someone, who shall remian nameless, started pressing the slide controls. I don't know what she did or how to get my display to light up full time again. She made the display go into hide mode some kind of way. The display will light up momentarily when changing stations or changing sources though. Can somebody help me?
  • 3 Answers
It's a bit too late but now only I'm seeing this!
It's in blackout mode!
Press and hold the FUNC key for at least 2-3 secs to activate and deactivate!
BTW, do any of u have a broken unit or a DC/DC converter for this! The small box connected to the end of the green/blue cable.
Posted on Nov 01, 2008
FGGS3045
Good Morning Ralph,
I understand that you were running the self-clean cycle on your Frigidaire range, model# FGGS3045, and it stopped and the control panel went dark. I also understand that there are no lights of any kind. I suggest that you give your appliance a hard reset by shutting the power off at your home's circuit breaker for 3-5 minutes. Once time has passed, restore power to your oven.
If you do receive power and the control panel and lights come on, you will have to reset the clock before doing anything else. You will reset the clock by pressing the "Set Clock" button. "CLO" will appear in the display area. You will then enter in the time and press the "Start" button. "CLO" will disappear and the time will show. Once you have reset the clock, try either turning your oven on a bake cycle or the self-clean cycle. If the same thing happens, to where the control panel goes dark and the lights go out, I suggest contacting your local authorized technician.
If you do not receive power, I suggest contacting your local authorized technician for assistance. They will be able to diagnose your range and determine why there are no lights coming on, as well as no power to the control panel, and if there is a temperature cutoff that might possibly be causing your range to not have power. Hope this is helpful.
-Best Regards-
WP
Mar 08, 2014 | Frigidaire 30" Slide-In Gas Range FGGS3045
GE error E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
credit to the original author of this solution rcadieux4444
Jun 30, 2012 | Computers & Internet
I have a Dayton controls programmable timer in my shop to control the bell for breaks, lunch, etc. I need to change the time of day to allow for the end of daylight savings time. I don't know how to...
Slide switch on bottom left to TIME. Press H key for hour - M key for minutes Then WEEK key until day of week. Press SET and current time is displayed. Slide bottom left switch back to AUTO and present time will display
Nov 07, 2011 | Amperite Dayton Solid State Timer On Delay...
New g.e. Dryer displays a fault code e61 on screen and will not power on or clear...this dryer is brand new...straight out of box with this fault code...
Sorry to read about your problem, I hope this helps you out.
you should have a electrician work on your wiring, with luck no further damage has happened, E61 means you have the neutral and the L2 wire either reversed or in the wrong position.
ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect the power for 30 seconds.
SEQUENCE (cont.)
(t02)
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE DBVH512EFWW Dryer
Hp530 screen real dark can see little how to
If it's due to the display settings on your computer, please do this-
Keep on holding down the function key(Fn - probably second key from bottom left) on the laptop and then press F10 key till you get the screen to become brighter.
Please let me know if it works, otherwise, we will have to gothrough a series of steps to resolve it.
Dec 27, 2009 | HP 530 Notebook
Screen went black
sounds like your monitor is shot or one of the connections in the back hope this helps regards Jim
Apr 20, 2009 | Computers & Internet
Screen went black
I don't know. I've never actually replaced parts in a monitor. If the bulb is expensive, it might be best to buy a new monitor. They're cheap nowadays. Or you can check if there's warranty on the monitor and it can probably be fixed for free.
Apr 20, 2009 | Acer X221WSD Monitor
Screeen went blank after changing resolution and hz appeared
refresh set to high boot safe mode change settings.
this has worked for me and XP.
Don
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
GE Dryer error code E61
SEQUENCE (cont.)
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code “E00”shall be displayed on the 7-segment display.
After clearing all errors from the fault log, the control shall display the no error “E00”code on the 7-segment display.
Mar 16, 2007 | GE DBVH512EFWW Dryer
Alpine CD Player CDA-9855 LIMITED QUANTITY ACT NOW Logo
126 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
