Question about Goodman GMS90703BXA Heater
Goodman seer 12 amps to high
Problem is that it's amps are high 20.19 total unit and it's breakin that breaker 40amps. purchase 2004. we cleaned it out all the coils yesterday and it was run at 16.99 amp regular and now it's started again,,,,waz up!!!! help we live in az
Breaker is bad
Posted on Sep 01, 2008
Difference in seer
i would check fan speed. it's probably on high. you might be moving more air with new system. a dirty evaporater on old unit woud have gave you a larger temperture drop.
Jun 16, 2014 | Goodman Heating & Cooling
How to wire high voltage goodman straight a/c package gpc1324 unit with 8kw heat kit
do any one have a old package unit is a goodman i want to see were heater on that package uint or take picture of that unit so i can see where the wire go at the heat
Aug 17, 2012 | Goodman Heating & Cooling
Need to how the power source will be hooked up, and how, it will wire into a 13 SEER Goodman Packaged Unit, with HKR-15 strips. wire size?= 15 Ft. run: panel to unit
Minim 20 amp circuit ... is this 110 or 220? You need to know.
20 amp circuit needs to have #12 wire. If 110 Volts, you need a black, white and green #12. If 220 Volts you need a black, a red, and a green. If you have anything IN the unit that needs 110 (probably not), you need black, Red, White and Green (bare) #12 wire. Definitely needs to be on a dedicated circuit. If your unit has a resistance heater (electric) you will need a 30 amp circuit (probably 220) which needs #10 wire minimum. 220 volt breakers are double. You will need two spaces in your panel box. Would not hurt to put in heavier wire (#8) protected by a 30 amp breaker ... $ is the governing factor.
Having said all of that --- you should be reminded that I dont even know what country you are in nor your prevailing voltage nor what your national or local codes require. My comments based on installing several Goodman products over several years on the Eastern Seaboard.
Aug 26, 2011 | Heating & Cooling
What seer is my goodman cl 30 1 fb and how many tons is it
If this is the model number of the unit, it would be a 2 1/2 ton unit. The seer I couldn't tell you with out seeing the manual. Could be a 10, 12, 13, cant tell with this information. Sorry.
Shastalaker7
A/C, & Heating Contractor
Feb 18, 2011 | Heating & Cooling
I cannot find the seer rating or tonage of a Goodman air conditioner serial number 9908524497
My books do not go back far enough to get you the Seer rating, it is a 5 ton unit and as the serial number shows it to be a 1999 model, it is probably a 10 SEER unit, maybe a 12 seer, but not likely, but I can tell you that it was manufactured on the 8th week of 1999.
I hope that I have helped, have a great day.
Sincerely,
Paul Gibson
Mar 31, 2010 | Goodman CKL60AR60 Air Conditioner
We have a Goodman CKL49-1 - 10 Seer - 4 Ton Condenser. One of the wires that fires the compressor keeps burning and, of course, the compressor won't come on. It is beginning to happen every couple of days....
A bad connection in the power wiring, the circuit breaker, disconnect, capacitor(s) or in the compressor contactor (worn contactor) can cause this due to very high resistance and subsequent heat production. If the unit will run, it should be amped checked to trace the cause.
This assumes that the wiring is correct and that the unit was functioning properly before these issues manifested themselves.
Jun 06, 2009 | Goodman CLQ36AR49 Air Conditioner
Looking for rating
http://www99.epinions.com/specs/pr-Goodman_Split_System_CLJ36AR42_Air_Conditioner
Please rate my response, thank you.
Jun 04, 2009 | Goodman CLJ36AR42 Air Conditioner
Extremely long time to get cool air with 5 ton 13 seer goodman heat pump which is 3 years old.
Check your filter. Make sure it is clean. Make sure the outdoor unit is operational. (power on). Clean your condenser coil with a garden hose. If possible check your evaporator coil. If it is dirty clean it. Your furnace (or air handler) blower speed should be set on high. All of your registers (supply & return) should be open and unobstructed. Check for proper thermostat settings. If none of this information solves your problem , then your units charge needs to be checked. You could be over or undercharged with freon.
Good luck......
May 06, 2009 | Goodman Heating & Cooling
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
